| Author |
Message |
Sam Vastano Regular
Posted: Tue Nov 27, 2012 6:48 am Post subject: Powertrol oil moving into Tranny |
Group,
I just pulled apart my 46 B to check where my Hydro oil was escaping to the tranny. The gasket on the powertrol cylinder seemed to be good so where else should I be looking? around the PTO shaft???
Sam |
| Back to top |
F-I-T Tractor Guru
Joined: 27 Feb 2002 Posts: 8447 Location: United States
Posted: Tue Nov 27, 2012 6:57 am Post subject: Re: Powertrol oil moving into Tranny |
| Sam Vastano wrote: | (quoted from post at 07:48:14 11/27/12) Group,
Sam |
Yep, most likely the pto cup/spring/bushing. |
| Back to top |
Jaybird46 Guest
Posted: Tue Nov 27, 2012 8:16 am Post subject: Re: Powertrol oil moving into Tranny |
Sam-The PTO pump shaft seal gets hard and worn-replacing is best option-had to do on JD 60-not to bad to put it in-stopped the leaking. I think the seal consists of two seals back to back-can get it through seal company if you can get part number of old one to cross-but put in two seals back to back (seal rubber out)
Good Luck |
| Back to top |
Sam Vastano Regular
Posted: Tue Nov 27, 2012 8:53 am Post subject: Re: Powertrol oil moving into Tranny |
Thanks! I will pull apart and get some new seals! |
| Back to top |
F-I-T Tractor Guru
Posted: Tue Nov 27, 2012 10:38 am Post subject: Re: Powertrol oil moving into Tranny |
| Jaybird46 wrote: | (quoted from post at 09:16:33 11/27/12) Sam-The PTO pump shaft seal gets hard and worn-replacing is best option-had to do on JD 60-not to bad to put it in-stopped the leaking. I think the seal consists of two seals back to back-can get it through seal company if you can get part number of old one to cross-but put in two seals back to back (seal rubber out)
Good Luck |
Wrong tractor! A "B" pto is not a '60 pto. It's a cup/spring/bushing. Look at the parts book and price that stuff first! |
| Back to top |
Sam Vastano Regular
Posted: Tue Nov 27, 2012 3:43 pm Post subject: Re: Powertrol oil moving into Tranny |
FIT,
I took some photos I do not see the seal???? Please help!
| Back to top |
Sam Vastano Regular
Posted: Tue Nov 27, 2012 3:45 pm Post subject: Re: Powertrol oil moving into Tranny |
Opps that was the outer seal,,, More photos:
| Back to top |
Sam Vastano Regular
Posted: Tue Nov 27, 2012 3:46 pm Post subject: Re: Powertrol oil moving into Tranny |
Shaft:
| Back to top |
Neven Regular
Posted: Tue Nov 27, 2012 8:31 pm Post subject: Re: Powertrol oil moving into Tranny |
Expensive but worth the fix. Just did it. |
| Back to top |
Pete in MD Long Time User
Joined: 09 Feb 2006 Posts: 892 Location: Millersville, MD
Posted: Tue Nov 27, 2012 8:49 pm Post subject: Re: Powertrol oil moving into Tranny |
Sam,
Looking at your 3rd picture. Slide the bronze cup off the shaft and you'll see the 2 flat rubber packings (seals). They're still available from Deere for about $5.00 each. Part# A668R. New ones look like large garden hose washers.
Inspect the front face of the cup. It should have a nice flat machined surface. It rides against a bronze bushing that should also have the same type of surface as the cup. The part# for the bushing is A621R. It's available from Deere for about $19.00.
The flat packings AND the cup & bushing work together to keep the Powr-Trol oil in the Powr-Trol sump. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
