Farmall M Engine Build
46mpuller
PostPosted: Tue Nov 27, 2012 7:50 am    Post subject: Farmall M Engine Build Reply to specific post Reply with quote
looking to build my stock m into a good 3-6mph tractor
wondering what size engine would be the best and what it takes to have a m compete and win at 6 mph
bp4455
PostPosted: Tue Nov 27, 2012 10:00 am    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
i would say 4.375x7= 421 cubes or a 4.375x7.25=436,unless you can run high rpms.
A.P.
PostPosted: Tue Nov 27, 2012 1:02 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
What weight classes? What are your tire rules - size and full cut/top cut/road worn?
46mpuller
PostPosted: Tue Nov 27, 2012 2:57 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
want to run 4500-6500lbs weight classes and would like to be able to turn 18.4-38 full cuts
dboll
PostPosted: Tue Nov 27, 2012 3:42 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
450-500 ci minimum on a good track and a short chain
A.P.
PostPosted: Tue Nov 27, 2012 5:36 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
On a biting clay track with a short chain sled at 6500# I would shoot for 500 cubes or a bit more. Are you going to try and build the engine yourself of farm it or portions of it out? If you are using a builder you should discuss your needs with them for the most cost effective and durable combinations.
LarryM
PostPosted: Tue Nov 27, 2012 6:23 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
6mph in 6500? Sounds like a five figure project to me. I have to get my house paid for before I play at that level.
north puller
PostPosted: Tue Nov 27, 2012 7:34 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
I've never played at that level, but 18.4-38 full cuts at 6500lb at 6mph is serious. I don't think 500 cubes will be enough to win.
Look at who you will be competing against. Another guy like you who asked the same question: what do I need to win? A 409, 421 or a 436 aint gonna cut it. The little tire 4mph guys all have those.
I would think that you need to be in the high 500's or near 600 cubes and over 150 HP. You are getting up with the very big boys with those tires and that speed.
46mpuller
PostPosted: Tue Nov 27, 2012 10:19 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
what will be the difference in price between 436 and somewhere in the 500 range
north puller
PostPosted: Wed Nov 28, 2012 5:06 am    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
Don't know for sure, but it will be a lot. 436 is an overbore in the block and a welded crank. Any bigger requires welded in sleeves and a billit 8" crank. Gonna be a LOT more money.
LCB
PostPosted: Wed Nov 28, 2012 9:05 am    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
I know of serval 500 cui Ms at 4&6MPH that do very well with 18.4X38 tires.
bp4455
PostPosted: Thu Nov 29, 2012 1:12 pm    Post subject: Re: Farmall M Engine Build Reply to specific post Reply with quote
ill give you a hint. just THE BLOCK prepped for 500+ motors. is in the $4500 range.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
