| Author |
Message |
weekendrancher New User
Posted: Tue Nov 27, 2012 9:32 am Post subject: M Carb problem |
I just rebuilt an M carb. It worked fine at first, then started leaking a stream of gas out of the very bottom of the fuel bowl. It will also try to start, but not run. Any ideas? the floats are NOT stuck.
I took it apart again and blew out the ports, etc. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50460 Location: Lake of the Ozarks area of MO
Posted: Tue Nov 27, 2012 9:39 am Post subject: Re: M Carb problem |
Needles seat not tight enough in the carb body or the needle not seating as it should or some dirt etc in the needle seat keeping the float from being able to stop the flow of gas. Of course that is if the float is in fact good and not filling with gas |
| Back to top |
Bob M Tractor Guru
Posted: Tue Nov 27, 2012 9:47 am Post subject: Re: M Carb problem |
For whatever reason the carb float needle valve is not closing when the bowl is filled.
Possibilities:
- Float level set too high
- Float rubbing on the side of the bowl (look for sloppy float hinge pivots)
- Gas-logged (sunken) float
- A bit of trash caught in the needle valve seat and a bad needle valve. (I've struggled with bad needles supplied with a couple different rebuild kits recently). |
| Back to top |
Bill in IL Long Time User
Posted: Tue Nov 27, 2012 9:49 am Post subject: Re: M Carb problem |
I have been through this before too. Did you install the gasket under the new seat when you installed it? BTDT stupid I know but something to think about.
Other that that look inside your fuel tank... is it clean? I installed a cheap filter inline between the carb and the tank. It works much better at getting crud than the sediment bowl. The filter can cause its own problems of airlocking the fuel line if you run out of gas but the end result of a carb not leaking (once its cleaned again) is worth it. |
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18506 Location: Southwest Iowa
Posted: Tue Nov 27, 2012 10:47 am Post subject: Re: M Carb problem |
| weekendrancher wrote: | (quoted from post at 10:32:29 11/27/12) I just rebuilt an M carb. It worked fine at first, then started leaking a stream of gas out of the very bottom of the fuel bowl. It will also try to start, but not run. Any ideas? the floats are NOT stuck.
Is the float hinge pin secure in the legs of the bracket?
If that pin is easily removeable using just you fingers, it is NOT secure, and it will NOT stay in place when you reassemble that carburetor. |
| Back to top |
Posted: Tue Nov 27, 2012 10:49 am Post subject: Re: M Carb problem |
The hinge pin is probably the most often over-looked and least understood part of the whole process of rebuilding the carburetor. |
| Back to top |
BigTone Regular
Posted: Tue Nov 27, 2012 12:13 pm Post subject: Re: M Carb problem |
Same thing happened to mine, check where the needle sits on the float, there may be a slight dimple from years of work and the needle is not seating correctly. I put in a new float, adjusted it and it works great now. best of luck |
| Back to top |
The Red Tractor Guru
Posted: Tue Nov 27, 2012 2:28 pm Post subject: Re: M Carb problem |
Check the gasket between the two halves. Make sure it is not overhanging inside the carburetor which could hang up the float. Trim it. |
| Back to top |
soybeanjoe Regular
Posted: Tue Nov 27, 2012 5:54 pm Post subject: Re: M Carb problem |
I have run into that problem when using an aftermarket carb rebuild kit. Carb will either leak gas out the bottom of the bowl or won't have gas in the bowl. I've found that replacing the needle valve & seat with a CIH brand usually eliminates the problem. An old IH mechanic was the one that recommended using the CIH needle valve & seat. |
| Back to top |
Posted: Wed Nov 28, 2012 7:32 am Post subject: Re: M Carb problem |
| soybeanjoe wrote: | | (quoted from post at 18:54:10 11/27/12) I have run into that problem when using an aftermarket carb rebuild kit. Carb will either leak gas out the bottom of the bowl or won't have gas in the bowl. I've found that replacing the needle valve & seat with a CIH brand usually eliminates the problem. An old IH mechanic was the one that recommended using the CIH needle valve & seat. |
If you clean the new needle valve and seat with aerosol carb cleaner before you install it, you won't have any problems either. GUARANTEED! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
