| Author |
Message |
tntleake Regular
Posted: Tue Nov 27, 2012 5:25 pm Post subject: Is this 200 block repairable |
Another tractor worth the money.?
Has new tires all the way around.He's asking 1K for it.
What would a bare block cost with a rebuild?
Click the link for the ad and it will take you to the craigslist ad and better photos
I have a super C and a 230
Untitled URL Link
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6406 Location: Delta,colorado
Posted: Tue Nov 27, 2012 5:47 pm Post subject: Re: Is this 200 block repairable |
Would be a nice addition...But the rear wheels look like Farmall H.What is hooked to the rear?Wts,wide front..a $500 tractor in my opinion.I could be wrong |
| Back to top |
Old-F20 Long Time User
Joined: 02 Jul 2008 Posts: 913 Location: Maxwell, Iowa
Posted: Tue Nov 27, 2012 5:53 pm Post subject: Re: Is this 200 block repairable |
blocks repairable. second what delta said on the rear wheels not being right.
id say 500 as well |
| Back to top |
tntleake Regular
Posted: Tue Nov 27, 2012 5:58 pm Post subject: Re: Is this 200 block repairable |
It has a fast hitch, maybe a 3pt adapter I waiting on a call from him.
They might be 38",I'll find out. |
| Back to top |
gene bender Tractor Guru
Posted: Tue Nov 27, 2012 6:07 pm Post subject: Re: Is this 200 block repairable |
If its not cracked between the cycls and just behind the carb it can be fixed with fiberglass,J-B Weld or rubber cement. The mower B has worked for 12yrs with fiberglass. And another on has been fixed with rubber cement 10 yrs ago and both work just fine but if the crack is between the cycls thats another story. |
| Back to top |
Dave_Id Tractor Guru
Posted: Tue Nov 27, 2012 6:42 pm Post subject: Re: Is this 200 block repairable |
It might be worth $500, but it could be just a can of worms to restore. Parts tractor at the most. |
| Back to top |
CenTex Farmall Long Time User
Joined: 04 Dec 2006 Posts: 686 Location: Central Texas
Posted: Tue Nov 27, 2012 6:48 pm Post subject: Re: Is this 200 block repairable |
It looks like the crack keeps going to the right between the stud and the cylinder. I think you are in new block territory. The new tires are certainly nice. Looks like it's been sitting inside so there shouldn't be any weathering. It's more like you're buying tires and getting tractor parts on the side. |
| Back to top |
teddy52food Tractor Guru
Posted: Tue Nov 27, 2012 6:50 pm Post subject: Re: Is this 200 block repairable |
From what I can see in the picture, the head gasket would seal it. Depends on how far that crack goes. |
| Back to top |
steve_in_mo Guest
Posted: Tue Nov 27, 2012 7:11 pm Post subject: Re: Is this 200 block repairable |
Looks to me like the crack extends into the bore, so the block is done for. There are a lot of those blocks around, though. Those are some big rear tires on that tractor, probably worth the $1,000. It's worth pursuing if you get the three-point hitch. |
| Back to top |
Fritz Maurer Long Time User
Posted: Tue Nov 27, 2012 7:26 pm Post subject: Re: Is this 200 block repairable |
It's more repairable than this block!!
| Back to top |
Posted: Tue Nov 27, 2012 8:07 pm Post subject: Re: Is this 200 block repairable |
Tracy,Susan's tractor(Chloe) block was cracked like that .The only 'repair' it got was a new head gasket.Trouble free for 5 years.....Your results may vary.Steve |
| Back to top |
LMack Long Time User
Posted: Tue Nov 27, 2012 8:10 pm Post subject: Re: Is this 200 block repairable |
I am not seeing the 2-Point Hitch yoke. The oversize tires indicate a pulling tractor so it will have a pulling hitch. The rear rims are not stock, notice the wedges. Scrap price at the max and you will not be getting much. He gave up on it because it was not cost effective to repair the cracked engine. I assure you that he would already have fixed the crack if it could be fixed. FYI there were no 1952 200 Farmalls. All were made in 1955. The grill says 200 but I would want to see the serial number. It may be an SC with a 200 grill. |
| Back to top |
Posted: Tue Nov 27, 2012 8:25 pm Post subject: Re: Is this 200 block repairable |
Better get _Four_ tubes of JB weld for that one! |
| Back to top |
tntleake Regular
Posted: Tue Nov 27, 2012 9:36 pm Post subject: Re: Is this 200 block repairable |
WOW |
| Back to top |
wisbaker Tractor Expert
Posted: Tue Nov 27, 2012 10:54 pm Post subject: Re: Is this 200 block repairable |
Anything can be fixed, the question is "is it worth fixing?" I'm guessing that it would be cheaper to find a usable block and rebuild OR find a good running engine. You are an adult so shop around and get an idea of what an engine will cost you add that to the price of the tractor and add 20%. Do you want to buy that tractor for that amount of money? What else could you buy for the same money? |
| Back to top |
