77 engine model #
pllr
PostPosted: Tue Nov 27, 2012 6:32 pm    Post subject: 77 engine model # Reply to specific post Reply with quote
I have a later model 77, has disc brakes, looking for a 3 5/8 bore overhaul kit, the supplier is asking for waukesha model #, block casting # is 185220, I know that is not it, thought maybe my reprint of the oliver shop manual would have it listed, do not see it in there...????
Tramway Guy
PostPosted: Tue Nov 27, 2012 9:20 pm    Post subject: Re: 77 engine model # Reply to specific post Reply with quote
Late model 77 with disc brakes is not necessarily a Super 77....
The model number for Waukesha would be a 185 series.
If the 77 is like the 88, the Super 77's would have different rod journal diameters than the regular 77.
Thompson Mike
PostPosted: Wed Nov 28, 2012 5:59 am    Post subject: Re: 77 engine model # Reply to specific post Reply with quote
The kits at Korves are on sale right now. Good time to buy one.
Christopher S.
PostPosted: Wed Nov 28, 2012 9:18 am    Post subject: Re: 77 engine model # Reply to specific post Reply with quote
Just for my own knowledge, why are you choosing the 3 5/8" kit instead of the 3 3/4" kit?
View user's profile AIM Address
j. Schwiebert
Guest
PostPosted: Wed Nov 28, 2012 9:20 am    Post subject: Re: 77 engine model # Reply to specific post Reply with quote
Get yourself a quality kit. You will need a different head gasket. What are you going to do with the tractor? A 3-5/8 kit with those little valves? I would get the head redone with either 550 or at least Super 77/770/88 valves if this is a gas tractor. YOU WILL WANT THE LARGER VALVES TO MAKE IT BREATHE BETTER. If it is a 77 diesel, forget the 3-5/8 as you will have crankshaft issues.
pllr
PostPosted: Wed Nov 28, 2012 6:34 pm    Post subject: Re: 77 engine model # Reply to specific post Reply with quote
There is listed the model 185 and a 194 waukesha, I am thinking the 194 must be for a super 77? I do not really need the added power of the 3 3/4 kit, I did see Korves has them on sale, will use for light field work, maybe 50 hours per year, run a small hammer mill, small aquare baler, rake hay, pull 9ft cut haybine, etc..it is a 77, does not have flat implement mounting pads....looking at a kit a company out of ohio sells, I think the supplier name is reilly ?? might be same ones Korves has? I am looking for better quality. The head was done about 4 years ago, has the bigger valves installed. Thanks for input.
