| Author |
Message |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6426 Location: Delta,colorado
Posted: Wed Nov 28, 2012 5:51 pm Post subject: Cab heater |
I was complaining that it gets COLD in the combine cabafter the sun sets.I was told that there is a 12volt heater available.Never seen/heard of such a thing.I would think that it would draw a LOT of power.If they do exist,where can I get one?Steve |
| Back to top |
flying belgian Tractor Expert
Posted: Wed Nov 28, 2012 6:47 pm Post subject: Re: Cab heater |
What do Deutz air cooled engines use? or them old Volkswagon cars? |
| Back to top |
casecollectorsc Long Time User
Posted: Wed Nov 28, 2012 6:55 pm Post subject: Re: Cab heater |
Got hot water heaters in my Case combines. About 12"x12"x12". On cold nites combining corn till about 2am they do a great job. You can open your coat and take the gloves off! Should be able to find one in a salvage yard out of a older machine. |
| Back to top |
marloweg Guest
Posted: Wed Nov 28, 2012 7:01 pm Post subject: Re: Cab heater |
VW had gas heaters in them |
| Back to top |
Nathaniel Watts Long Time User
Posted: Wed Nov 28, 2012 7:06 pm Post subject: Re: Cab heater |
The Gleaners with Deutz engines use engine oil for heat. |
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Wed Nov 28, 2012 7:27 pm Post subject: Re: Cab heater |
Steve here is one in my 660 Case, you can stil buy these types new, last one I got was bought at a truck parts supply shop for around 140.00 came with a speed switch cnt
| Back to top |
rustyplow Regular
Posted: Wed Nov 28, 2012 7:54 pm Post subject: Re: Cab heater |
Or how bout a rear heater out of an old school bus? |
| Back to top |
Averyman Regular
Posted: Wed Nov 28, 2012 9:21 pm Post subject: Re: Cab heater |
I have used a 12 volt heater, they do help a bit but I would recommend going with with one using your engine coolant, One from a school bus sounds like a good idea or with a little ingenuity and tin work you can make one out of a car or truck heater core and fan. |
| Back to top |
JMS/.MN Tractor Guru
Posted: Wed Nov 28, 2012 9:40 pm Post subject: Re: Cab heater |
Folks had a 41 Ford with a Southwind gas heater. Still available thru Stewart-Warner. Just googled them. |
| Back to top |
JD Seller Tractor Guru
Posted: Thu Nov 29, 2012 12:19 am Post subject: Re: Cab heater |
Steve: I ran a JD 95 for years and the factory heater under the seat would run you out of the cab. Don't any of your combines have heaters??? The cabs on the 45,55,95,105 all used the same heater. It was mounted under the seat. There was a fan behind it to push the heat out on your feet.
On things that did not have a factory heater I have used propane tent heaters with no problems. A cylinder would last a few days and it kept you nice and toasty. You may have a window fogging issue but usually if you run a fan it does not happen much.
Here is a link to one kind of like what I had.
Propane tent heater.
| Back to top |
Dick2 Tractor Guru
Posted: Thu Nov 29, 2012 12:52 am Post subject: Re: Cab heater |
The energy in a gallon of fuel is roughly divided into 3rds. One third is used to power the machine; 1/3 goes out the exhaust and 1/3 goes out through the coolant.
You might as well use some of that wasted energy by tapping into the coolant for a heater in the cab. A little plumbing and wiring and you can be warm. |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Thu Nov 29, 2012 3:31 am Post subject: Re: Cab heater |
I had an old Stieger on which all the climate controls had been removed/disabled.
I snooped around the internet until I found just what you're talking about.
I wasn't afraid to install it as the Steiger had a huge alternator, and it wasn't far from the cab to run the heavy wires. But it didn't give off much heat.
I don't think I'd want to put one in a combine. Plus, without any heat from the engine/drivetrain, the little electric heater probably won't even be noticeable.
I took one of those box heaters out of an old backhoe I would give you. But one of us is on the wrong end of the country! |
| Back to top |
Jim Knapp Regular
Posted: Thu Nov 29, 2012 5:56 am Post subject: Re: Cab heater |
I replaced the leaking heater in my Gleaner F with a unit from NAPA several years ago. Turned out to be made in Ohio by the same company that made the origional. Measures about 10 x 10 x 10 inches. Compleat unit cost less than a new core from Agco.
Jim |
| Back to top |
fixerupper Tractor Guru
Joined: 12 Oct 2003 Posts: 6909 Location: Albert City Iowa
Posted: Thu Nov 29, 2012 11:11 am Post subject: Re: Cab heater |
JD, in my 105 the heater was facing the door so the door stayed warm and clear but the windshield frosted and my feet were cold. I unbolted the heater and turned it so it blew forward at my feet. BIG difference. I had to put a valve in the heater hose behind the seat to keep my feet from melting! Jim |
| Back to top |
Butch(OH) Tractor Expert
Posted: Thu Nov 29, 2012 11:33 am Post subject: Re: Cab heater |
Yup, I have one of those NAPA units in my skidsteer loader. |
| Back to top |
