| Author |
Message |
AKdually New User
Posted: Wed Nov 28, 2012 7:58 pm Post subject: Farmall F-12 rear tire tube change? |
I got the outer ring off and the new tire and tube in. Not able to get the one piece outer ring back on. Pops off when I get about two feet from having it on. Any clue? |
| Back to top |
Oldiron29 Long Time User
Posted: Thu Nov 29, 2012 3:45 am Post subject: Re: Farmall F-12 rear tire tube change? |
The rim groove and the ring groove must be clean of rust and paint build up for them to lock together. I find it best to lay wheel flat on ground and stand on top of ring so it does not pop out when I am working on it. oldiron29 |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 947 Location: West central Wisconsin
Posted: Thu Nov 29, 2012 4:22 am Post subject: Re: Farmall F-12 rear tire tube change? |
I am sure you probely know this, but when you air up the tire make sure you protect yourself with chains around the tire if you don't have a tire cage.
Bob |
| Back to top |
mkirsch Tractor Guru
Posted: Thu Nov 29, 2012 5:21 am Post subject: Re: Farmall F-12 rear tire tube change? |
Try using some nylon ratchet straps to hold the ring in place while you work the last little bit onto the rim.
When airing up, I would also use a locking air chuck, and control the air with the valve on the air compressor from as far away as possible, rather than stand there and hold the chuck. |
| Back to top |
John M Tractor Guru
Joined: 04 Feb 1999 Posts: 4993 Location: Gray Court, SC
Posted: Thu Nov 29, 2012 5:26 am Post subject: Re: Farmall F-12 rear tire tube change? |
I assume you have the same rims I do on mine, I was able to pry on that little lock/clamp/whatever its called just enough to let the ring slip down far enough to get it on. |
| Back to top |
AKdually New User
Posted: Thu Nov 29, 2012 10:34 am Post subject: Re: Farmall F-12 rear tire tube change? |
Thanks for the replies. Have a few moreideas to try now. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
