Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
2N oil in radiator
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
MoMac
PostPosted: Thu Nov 29, 2012 6:21 am    Post subject: 2N oil in radiator Reply to specific post Reply with quote
Hello. Picked up a 2N,original owner,been sitting since spring. Everything looks original except 12 volt conversion. Has oil in radiator,alot. Any ideas on where to start looking for cause or if this a regular problem for these tractors? Not used to working on flat heads. Thanks, Mike.
souNdguy
PostPosted: Thu Nov 29, 2012 6:54 am    Post subject: Re: 2N oil in radiator Reply to specific post Reply with quote
first you need to find out if it really is oil inthe rad.
many times a blown head hasket will let oily residue from combustion into the rad.. over time it makes a sheel and can emulsify into a layer that sets on top after water flow stops.
that is quite common and can usually be detected with a compression test and leakdown test, and then a head gasket change if indicated.
there are no oil ports in the head.. so.. if it ruly is oil.. that means block issues.. and I'd look for water int he oil.. however.. keep in mind oil ressure is usually (hopefully) higher than the psi rating onthe rad cap.. so real oil in the water, but no water in the oil is still a possibility.. though with the engine pan off and a leak down tester.. you could find it.
me?
i'd do a comp test.. and then flusht he rad with a commercial flush product to cut the oil.. then refill with water and see what happens... if comp test indicates blown hg.. then repalce as indicated.. etc.
post back for more help if needed.
MoMac
PostPosted: Thu Nov 29, 2012 6:59 am    Post subject: Re: 2N oil in radiator Reply to specific post Reply with quote
Thanks for the reply soundguy. As soon as I can get it home I'll get into it. Mike
souNdguy
PostPosted: Thu Nov 29, 2012 11:36 am    Post subject: Re: 2N oil in radiator Reply to specific post Reply with quote
post back what ya find.. we can help!
