Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4020 sychro adjustment
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Roger in Iowa
PostPosted: Thu Nov 29, 2012 2:21 pm    Post subject: 4020 sychro adjustment Reply to specific post Reply with quote
I know I have read solution but cannot find it.
1970 4020 sychro, overshifts in the higher gear of the range, i.e. 3, 5, 7 and 8. All work, but just have to carefully get it in the above gears. 5, 7 and 8 worse but have learned to not shift it so far downward on these gears.
Have cover off for other reasons so now is the time to fix.
Thanks for help.
Jim Knapp
PostPosted: Thu Nov 29, 2012 2:35 pm    Post subject: Re: 4020 sychro adjustment Reply to specific post Reply with quote
Might just be the clevises on the shifter rods from the shifter under the dash to the transmission.
Jim
Tx Jim
PostPosted: Fri Nov 30, 2012 4:19 am    Post subject: Re: 4020 sychro adjustment Reply to specific post Reply with quote
Roger is there very much side to side movement in the shift quadrants in the dash?? If so it needs to be shimmed.
tim s
PostPosted: Fri Nov 30, 2012 5:21 am    Post subject: Re: 4020 sychro adjustment Reply to specific post Reply with quote
Put new bushings, clevis and pins,shims in the upper shifter to start with, the adjustments is basically centering the shifter in each gear. Also I have seen the shifter pivot pin get loose and wear the hole a bit, when this happens I pean the hole to "swell" it enough to hold the pin, then goob it up with some JB weld to fill in the void them tighten it up good and let it set for a day. This works fairly good most of the time, but only if you swell the hole first and then depend on the JB weld to finish the fit...And if this don"t solve the problem get the splitting stands out.....
tomstractorsandtoys1
PostPosted: Fri Nov 30, 2012 7:04 am    Post subject: Re: 4020 sychro adjustment Reply to specific post Reply with quote
Tim have you ever replaced the pointers behind the plugs on the side of the trans that go against the cams? We replace them with a ball and retainer like the later 4230's used,it seems to help center the cam better as many are wore bad from the pointer.We also replace the springs.
tim s
PostPosted: Fri Nov 30, 2012 7:34 am    Post subject: Re: 4020 sychro adjustment Reply to specific post Reply with quote
Yes when I re-build a transmission I include those with the parts, every little bit helps, but "most" of the time a shift problem is worn sychronizers...
