Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Power-Trol idler shaft
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Ted K
PostPosted: Thu Nov 29, 2012 2:41 pm    Post subject: Power-Trol idler shaft Reply to specific post Reply with quote
Do any of you know of someone or some supplier that makes the Power-Trol idler shaft to fit a "60"? I can have bushings made for the gear but would presume the shaft is hardened. Had thought of making my own and hardening the surface with carborizing compound but that would probably only go .002"-.003" deep. Have called several bone yards and they all have none or one that"s galled badly. Any ideas are appreciated.
Ted K
F-I-T
PostPosted: Thu Nov 29, 2012 4:59 pm    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
Ted K wrote:
(quoted from post at 15:41:13 11/29/12) Do any of you know of someone or some supplier that makes the Power-Trol idler shaft to fit a "60"? I can have bushings made for the gear but would presume the shaft is hardened. Had thought of making my own and hardening the surface with carborizing compound but that would probably only go .002"-.003" deep. Have called several bone yards and they all have none or one that"s galled badly. Any ideas are appreciated.
Ted K
How bad do you want one? Deere sells them new for $110 or so.
PJH
PostPosted: Thu Nov 29, 2012 7:27 pm    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
I made that repair twice on my 630. Second time the idler gear galded to the shaft and I had to cut it out with a torch. I got all the parts at JD, as Frank suggested. I also added an oil line to the right end of the housing to lube the shaft. It runs cool now.
F-I-T
PostPosted: Thu Nov 29, 2012 7:45 pm    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
PJH wrote:
(quoted from post at 20:27:18 11/29/12) I made that repair twice on my 630. Second time the idler gear galded to the shaft and I had to cut it out with a torch. I got all the parts at JD, as Frank suggested. I also added an oil line to the right end of the housing to lube the shaft. It runs cool now.
I have heard a lot of folks who added extra oiling to the pump drive.
Ted K
PostPosted: Fri Nov 30, 2012 2:30 am    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
Thanks for the replies.
I wasn"t aware JD still had the shafts available since they no longer have the bushings for the gear. I"ll check it out as well as adding an oil line.
Ted K
Mike M
PostPosted: Fri Nov 30, 2012 6:17 am    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
Also the late AR used the same set up in case any of your bone yards have one of these. The one I had even had needle bearings in it instead of a bushing. Not sure why Deere changed to a bushing on later models ?
F-I-T
PostPosted: Fri Nov 30, 2012 6:33 am    Post subject: Re: Power-Trol idler shaft Reply to specific post Reply with quote
Ted K wrote:
(quoted from post at 03:30:19 11/30/12) Thanks for the replies.
Ted K
Pretty sure Deere never did sell the gear bushings separately, just furnished a fully bushed gear. Now might be the time to have it bored if necessary, and to install a needle bearing. Or maybe someone on here has a badly galled gear you can use to experiment with.
