| Author |
Message |
Rustidiot Regular
Posted: Sat Dec 01, 2012 6:00 pm Post subject: Case 600 |
I have a Case 600 LP serial #8100963. I read where only 350 were made. Is that correct? Thanks for your help |
| Back to top |
Tommy Railsback Regular
Posted: Sat Dec 01, 2012 6:35 pm Post subject: Re: Case 600 |
That is correct; I know of one that was junked out at Oberlin, KS. |
| Back to top |
Rustidiot Regular
Posted: Sat Dec 01, 2012 9:07 pm Post subject: Re: Case 600 |
Thanks Tommy. Mine is complete except that someone stole the LP carb and the magneto before I could get it hauled home. I need to find those items before I can crank it. Good compression. I havent found the timing marks yet. |
| Back to top |
caseman-d Tractor Expert
Posted: Sun Dec 02, 2012 5:16 am Post subject: Re: Case 600 |
Dist or mag can be used. I have a 619 lp engine on a LA and it had a up right dist. mounted on it but some one removed the dist. I found a 6 cylinder mag from a Oliver tractor as they are more popular.
The carb. from a 900 or 930lp should work for you.
caseman-d |
| Back to top |
casecollectorsc Long Time User
Posted: Sun Dec 02, 2012 6:16 am Post subject: Re: Case 600 |
The LP carb from a LA Case will work also. Cubic inches of the engines is real close so carb will be big enough. I've got an LA carb on a 930 rowcrop and it works great! |
| Back to top |
mEl Tractor Guru
Posted: Sun Dec 02, 2012 12:25 pm Post subject: Re: Case 600 |
| casecollectorsc wrote: | | (quoted from post at 07:16:10 12/02/12) The LP carb from a LA Case will work also. Cubic inches of the engines is real close so carb will be big enough. I've got an LA carb on a 930 rowcrop and it works great! |
I have a Delco upright Mag replacer in 6 cyl if anyone can use it. Would be glad to talk.
mEl |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
