Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1070 no hydralic pressure
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
MTC
PostPosted: Sun Dec 02, 2012 5:32 am    Post subject: 1070 no hydralic pressure Reply to specific post Reply with quote
I have a 1070 which was low on hydralic fluid--no power steering,no clutch,no brakes,no PTO no nothing with engine running.The gauge on dash said no pressure.Went and filled to proper level and still no pressure.What went wrong here?? thanks
Paul A Young
PostPosted: Sun Dec 02, 2012 5:36 am    Post subject: Re: 1070 no hydralic pressure Reply to specific post Reply with quote
Filters plugged ?
Case Nutty 1660
PostPosted: Sun Dec 02, 2012 6:04 am    Post subject: Re: 1070 no hydralic pressure Reply to specific post Reply with quote
pump may be air locked have seen this before especialy if pump is getting weak or suction screen is getting plugged with debris, try starting engine and wrapping throttle wide open and see if it will pick up oil, that usally will make them prime and its better than running with a airlock cnt
casecollectorsc
PostPosted: Sun Dec 02, 2012 6:08 am    Post subject: Re: 1070 no hydralic pressure Reply to specific post Reply with quote
Shift the power shift into 2nd or 3rd and watch the gauge to see if you get pressure in one of those positions.
mEl
PostPosted: Sun Dec 02, 2012 6:18 am    Post subject: Re: 1070 no hydralic pressure Reply to specific post Reply with quote
What year is it? On early models the pump was driven off the torque limiter plate which can fail, the spring center can go bad and the shaft driving the pump stop.
The pump also could have a complete meltdown internally. There is a suction screen on the bottom of the pto housing accessable only after removing the complete pto housing, I have seen dirty ones but it would be almost unconcievable to be plugged that completely.
Orings at the pump suction pipe, not likely but......
Although not a good thing , plugged filters will not keep oil from getting to where it belongs as there are filter bypass cartridges in each filter ( assuming its a powershift) that will open and allow unfiltered oil to go through.
Just read casecollectors post and am ammending mine in response. The fact that he lost steering and brakes also suggests a total pump failure. No steering and brake return will seriousl degrade powershifting as the steering return returns to sump through the 75 psi lube pressure regulator which operates the reverse lockout spool which has lands which also direct clutching oil flow. A powershift failure alone will not cause total system failure. However , the more info we have will help zero in on the problem.
mEl
Eldo case
PostPosted: Sun Dec 02, 2012 6:41 am    Post subject: Re: 1070 no hydralic pressure Reply to specific post Reply with quote
If it is a yellow early model like mine this is the trouble! Need to split at the bell housing.
