Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Fuel tank reserve
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
wcurley000
PostPosted: Sun Dec 02, 2012 8:51 am    Post subject: Fuel tank reserve Reply to specific post Reply with quote
The manual for my 8N says it has a reserve tank. How does it work?
old
PostPosted: Sun Dec 02, 2012 9:02 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Simple. You open the sediment bowl valve 2 turns and it is on normal open it all the way and it is on reserve if it has the factory sediment bowl assembly on it that is
Bruce (VA)
PostPosted: Sun Dec 02, 2012 9:04 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
No, it does not have a reserve tank.
The tank holds 10 gallons.
If you open the sediment bowl valve 2 turns (no more, no less) as the manual says, it will provide 9 gallons of gas. If you want to get that extra (reserve) gallon, open the valve all the way.
All of this assumes:
1. You have the OEM style sediment bowl.
2. The lower orifice on the sediment bowl standpipe is not clogged (and they usually are).
The OEM bowl is on the left in the pic. The others are off-shore junk.
75 Tips
wcurley000
PostPosted: Sun Dec 02, 2012 9:15 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Thank you Burce & Old. My manual does not say anything about how to set the reserve using the valve. I also have a Jubilee it has the round valve handle. My 8n has the lever. I have never moved it and have been runnig out of gas with about 1.5 inches of gas in the tank. Thanks again.
Bruce (VA)
PostPosted: Sun Dec 02, 2012 9:39 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
" My 8n has the lever."
As old & I both said.......it needs to be the OEM sediment bowl to have a reserve.
Look at the picture.
The OEM bowl has a knob, not a lever.
75 Tips
old
PostPosted: Sun Dec 02, 2012 9:40 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
If you have that 1-2 inches of gas in the bottom of the tank that means the reserve is working as it should or the reserve part of the sediment bowl is clogged up which happen often
Caryc
wcurley000 wrote:
(quoted from post at 10:15:57 12/02/12) Thank you Burce & Old. My manual does not say anything about how to set the reserve using the valve. I also have a Jubilee it has the round valve handle. My 8n has the lever. I have never moved it and have been runnig out of gas with about 1.5 inches of gas in the tank. Thanks again.
Does this mean you never shut off the fuel supply?
Bruce (VA)
PostPosted: Sun Dec 02, 2012 9:47 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
" Does this mean you never shut off the fuel supply? "
Excellent point.
Tip # 9.
75 Tips
flembo
PostPosted: Sun Dec 02, 2012 10:24 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
I believe the sedement bowl he refers to is the one shown this one was off a 46 2n also shown in the original service manual
flembo
PostPosted: Sun Dec 02, 2012 10:30 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
wcurlyoo if you look close at your sedement bowl you should be able to make out the R for reserve and M for main turn handle to point to left for reserve or right for main that is if your bowl is in act the same as I have pictured
flembo
PostPosted: Sun Dec 02, 2012 10:40 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Oh and straight down is off you should get in the habit off of turning it off
GO FIGGER, John,PA
PostPosted: Sun Dec 02, 2012 11:50 am    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Consider this..........10 gal of gas.
When she spits at YA.........start heading to the "barn". Approx. 45 min, she should know what STALL was YOURS. NIGHT OWL.
GARFIELD
Paul in Edmonton
PostPosted: Sun Dec 02, 2012 12:03 pm    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Question for you Bruce: Where can I get a new sediment bowl that's not junk? I got one from the "other" 8N parts website, and it's junk. But the valve stem is wrecked on my original...
-Paul
Bruce (VA)
PostPosted: Sun Dec 02, 2012 12:56 pm    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
I got a couple of good ones from Just8N's. I've heard YT has good ones too.
75 Tips
Bruce (VA)
PostPosted: Sun Dec 02, 2012 12:58 pm    Post subject: Re: Fuel tank reserve Reply to specific post Reply with quote
Could be.
It's possible he has a 9N/2N bowl on an 8N.
75 Tips
Goto page 1, 2  Next
Page 1 of 2
