| Author |
Message |
NY 986 Tractor Expert
Posted: Sun Dec 02, 2012 9:56 am Post subject: 30 series 404 pistons |
I remember a thread a while back about an upgrade replacement that increased compression and improved starting. I know somebody that is going to do a overhaul on a 4430 this winter and wanted to advise him on this. |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5981 Location: Somerset Ohio
Posted: Sun Dec 02, 2012 10:00 am Post subject: Re: 30 series 404 pistons |
I think the new style pistons sub up to the new O/H kits, this is one of the benefits of using Deere parts over after market... |
| Back to top |
cottonplant Regular
Posted: Sun Dec 02, 2012 4:23 pm Post subject: Re: 30 series 404 pistons |
I owned a hard starting 4230 for years. Funny thing about the 30 series hard cold starting thing is you might talk to someone who says they have one that starts fine while others agree theres just won't start in any temperature without ether.Please let us know how the new style kit affects starting. |
| Back to top |
Mike in Ne Regular
Posted: Sun Dec 02, 2012 9:16 pm Post subject: Re: 30 series 404 pistons |
I think it is Reliance that makes Hyper-Formance kits with the upgraded pistons. |
| Back to top |
JDBert Regular
Posted: Mon Dec 03, 2012 7:31 am Post subject: Re: 30 series 404 pistons |
Mike is correct. The head and valves should also be redone- the 404's tuliped the valves bad and caused hard starting. Also need to make sure injection pump and injectors are up to snuff. A pair of 12 volt batterys hooked in parrallel instead of the 6volts hooked in series is also a must have. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23705 Location: in front of computer
Posted: Mon Dec 03, 2012 7:47 am Post subject: Re: 30 series 404 pistons |
Is the overhaul planned because of low power, oil consumption or pitted sleeves? Or is the tractor just a dog to start in cold weather? Is somebody pounding it with ether?
40F and below it should be plugged in to pre warm anyways?
Has anybody tried the $15 destroker and measuring voltage at the starter WHILE cranking?
Somebody maybe about to spend a wad of overhaul cash over an old set of battery cables or a seeping high pressure valve? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
