| Author |
Message |
Bobby 9891 Regular
Posted: Sun Dec 02, 2012 11:06 am Post subject: Rear wheel popping |
I have a 49 "C" NF & the rear wheels make a popping noise when the tractor has side to side movement. Looks like the movement is between the wheel & hub - I can"t tighten them any more. Some of the bolt heads are flush with the wedge. Just wondering if it has the right wedges for that wheel ??
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Sun Dec 02, 2012 11:15 am Post subject: Re: Rear wheel popping |
Each wheel is supposed to have two like the one in the photo, which are fitted in adjacent holes. To tighten the rim move the tractor so that the two wedges like the one in the photo are on the lower half of the wheel, turn the bolt heads on the other two wedges clockwise as far as possible with a wrench(which should tighten the wedges against the rim) then hold the bolt there with a wrench and tighten the nut. The two wedges on top have eccentric bolts in them which look like a cam on a camshaft in an engine and allow for tightening and loosening of the wedges.
Zach |
| Back to top |
steve(ill) Tractor Expert
Posted: Sun Dec 02, 2012 11:30 am Post subject: Re: Rear wheel popping |
if the clamps are worn or not enough adjustment, you can add a piece of shim stock in the VEE between the clamp and the rim.. about an inch above your finger in the photo. Two of the locks are stationary (your finger is one one of them). The other two turn on a cam as mentioned. Loosen those two and shove a .030 shim between the rim and the clamp and retighten. Might need two shims. |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 02, 2012 1:36 pm Post subject: Re: Rear wheel popping |
Thanks - I had 1 bolt on each wheel somewhat loose. I snuged them down best as I could - still some slack between the wheel & hub. I guess I should try shimming them - I really don't like that little bit of movement !! |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50404 Location: Lake of the Ozarks area of MO
Posted: Sun Dec 02, 2012 4:09 pm Post subject: Re: Rear wheel popping |
Are you sure you have the 2 non-cam wedges.bolts side by side and the cammed ones side by side and tight??. If you have the 2 sets in the wrong places you will never get them to stay tight and one day the rim will fall off. By the way guess how I learned that one |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 02, 2012 4:36 pm Post subject: Re: Rear wheel popping |
Yes the cam lock wedges are across from each other & one wheel has 3 cam locks - looks like they welded some extra stops on the wheel to fit that wedge on ! Iwas told the wheel could fall off & believe me I don't want to experience that like some people do !!! Should I use a impact to tighten or hand only ? I was afraid to use the impact for fear of breaking the bolts off ! |
| Back to top |
old Tractor Guru
Posted: Sun Dec 02, 2012 4:49 pm Post subject: Re: Rear wheel popping |
The cam locks should be side by side not across from each other. If you have the wheel this way the cam locks should be #1 at 12 o'clock and the next one at the 3 then the non-cam ones at 6 and 9 NEVER top and bottom or 3 and 9 |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 02, 2012 5:02 pm Post subject: Re: Rear wheel popping |
The cam locks are across from each other 3 & 9 And the other wheel only has one cam lock ! I guess thats why I cant keep them tight. Thanks OLD I'll change them up !! Will the bolts stand up to a impact or hand tighten only ?? |
| Back to top |
dakota dave Regular
Posted: Sun Dec 02, 2012 5:17 pm Post subject: Re: Rear wheel popping |
The cam locks have a cross on the head. When the long arm of the cross points to the rim that is as tight as it will go. They must be held in place and the nuts tightened on the back side. Its pretty hard to get an impact in there. you wont break the bolt with an impact. Also check the two stationary locks to make sure thier not loose. one of the straight locks must be between the drive lugs like you have in the photo. |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 02, 2012 6:05 pm Post subject: Re: Rear wheel popping |
Thanks - tomorrow I'll change them around. |
| Back to top |
old Tractor Guru
Posted: Sun Dec 02, 2012 6:13 pm Post subject: Re: Rear wheel popping |
I use my impact gun on them due to the fact they do over time rust up and are next to impossible to free up |
| Back to top |
