Allis C front end
Zachary Hoyt
PostPosted: Sun Dec 02, 2012 11:50 am    Post subject: Allis C front end Reply to specific post Reply with quote
I just traded for a couple of Allis tractors, a C with a B front end on it and a B parts tractor. I would like to put the C back to a narrow front, the current setup is pretty ugly and rough. The C steering rod(the "chicken roost") was cut and welded to the B front end rod, so I think I need the C rod and the C front pedestal assembly. If anyone has a lead on those parts or know if there are other parts I also need I would be very thankful. I think that the front rims will swap over but I am not sure. I will get some pictures soon.
Zach
old
PostPosted: Sun Dec 02, 2012 4:06 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
You do not need a lead you just need a way to pick them up. I have 1 maybe 2 C front ends laying around and had a guy looking for the C steering rod so I know I have it since he never got back to me on it. E-Mail is open as always
Zachary Hoyt
PostPosted: Sun Dec 02, 2012 6:21 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
Thanks, I sent an email.
Zach
Zachary Hoyt
PostPosted: Sun Dec 02, 2012 6:33 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
I am wondering what the rod behind the seat on the C is for, if it was part of the cultivator or something. I have never seen a Monroe seat with the spring pointing up like that, but it seems to be the way it was made from what I have found online. I am going to put the radiator from the B on the C since the C engine is ready to run and the B engine has a big hole in the block. Then I will part out the rest of the B.
Zach
steve(ill)
PostPosted: Mon Dec 03, 2012 6:23 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
THe bar behind the seat is called the rock shaft. It normally has two arms attached to it. Serves the same purpose as the lifting arms on a 3 point hitch. ON the Allis, you pin the plow, disc, blade under the transmission, and the two arms on the rock shaft "lift" the attachement when connected to a cylinder.
steve(ill)
PostPosted: Mon Dec 03, 2012 6:26 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
http://www.tractorshed.com/cgi-bin/gallery/gallery_pic.cgi?pic=http;//www.tractorshed.com/gallery/iphotos/i50493.jpg&firstrec=124&Parameter=allis&w=iphotos&cc=0
Untitled URL Link
Zachary Hoyt
PostPosted: Tue Dec 04, 2012 3:37 pm    Post subject: Re: Allis C front end Reply to specific post Reply with quote
Thanks, that makes sense now that you have explained it.
Zach
