valve cover c123
TUCKAWAY
PostPosted: Sun Dec 02, 2012 1:02 pm    Post subject: valve cover c123 Reply to specific post Reply with quote
I have nuts on each end of rocker arms should they be there or take them off and install valve cover? valve cover secures each end of rocker arms right? thanks
uncle henry
PostPosted: Sun Dec 02, 2012 1:04 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
should be four nuts two for rocker arms two for valve cover
TUCKAWAY
PostPosted: Sun Dec 02, 2012 1:20 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
thanks valve cover will not bottom down feels like something in way? any ideas
uncle henry
PostPosted: Sun Dec 02, 2012 3:40 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
may not have the bolts in the head deep enough
gene bender
PostPosted: Sun Dec 02, 2012 5:23 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
Are you putting it on backwards give it a half turn the nuts on the rockshaft hold down the rocker assy. Other hold the cover in place.
TUCKAWAY
PostPosted: Sun Dec 02, 2012 6:16 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
gene,uncle thanks for help, cover turned right to clear oil spout under cover , seems nuts on rocker stops cover from sealing on gasket,would thinner nuts on rocker work to allow cover to seal on gasket?
uncle henry
PostPosted: Sun Dec 02, 2012 7:20 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
here is a picture of how much is sticking out of mine
John B.
PostPosted: Sun Dec 02, 2012 7:23 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
I don't think he means how much bolt sticks out of the valve cover as much as he means the valve cover is not seating on its gasket.
TUCKAWAY
PostPosted: Sun Dec 02, 2012 7:55 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
john b is right , if I take the nuts off the rocker brackets then the cover will snug down on gasket. thanks to all.what am I doing wrong/
gene bender
PostPosted: Sun Dec 02, 2012 10:16 pm    Post subject: Re: valve cover c123 Reply to specific post Reply with quote
I dont see why the cover wont fit all the way down. Have you changed the rockshaft assy or what did you do thatnow the tappet cover will not go down to the gasket. Ive had tons of them apart and never any problems with the cover not fitting you are sure its not on backwards as thats the only way i can think of why it will not go down to the gasket.
