| Author |
Message |
Eddie7295 New User
Posted: Sun Dec 02, 2012 2:21 pm Post subject: lucas oil stabilizer in powershift |
Would like to get yours guys thoughts on putting two gallon of lucas in the hydralic oil on a 870 powershift. |
| Back to top |
JGarner Tractor Expert
Posted: Sun Dec 02, 2012 3:18 pm Post subject: Re: lucas oil stabilizer in powershift |
I think Case TCH is a better choice.
Jim |
| Back to top |
dboll Guest
Posted: Sun Dec 02, 2012 4:03 pm Post subject: Re: lucas oil stabilizer in powershift |
absolutely not |
| Back to top |
DKase Tractor Expert
Posted: Sun Dec 02, 2012 5:00 pm Post subject: Re: lucas oil stabilizer in powershift |
TCH goes in a COM. HyTran goes in a power shift. |
| Back to top |
Moline_guy Long Time User
Joined: 07 Aug 2006 Posts: 1287 Location: Northcentral SD
Posted: Sun Dec 02, 2012 5:35 pm Post subject: Re: lucas oil stabilizer in powershift |
Hytran only, best and safest trans oil out there and use it by itself. Paid 13.70/ gallon bulk the other day, seems way too high, but you just can't beat it for all season hydraulic and rear end oil. |
| Back to top |
NEKS Long Time User
Posted: Sun Dec 02, 2012 6:05 pm Post subject: Re: lucas oil stabilizer in powershift |
It could be one is not compatable with the other, then what would you have. Why would you not trust Hy-Trans or other major brands of hyd. oil to do the job it suppose too. |
| Back to top |
j hikemper Guest
Posted: Sun Dec 02, 2012 6:54 pm Post subject: Re: lucas oil stabilizer in powershift |
as others state HY-Tran should do the power shiftall the good you need ,But i did not hurt my 1070 with a quart of tranny slip ,, When my 1070 was resurrected after sittiung some 8 yrs ,,I LATER LEARNED it Really had tranny adjustment problems ,,1st thingg i did was change all fluids ,tranny filters were ancient..put in new hy tran and a qt of Lucas Tranny Slip..It did help the stiff range shifter but i still could not get 1st and 3rd range easily ,sent the 1070 to the ihc dealer, they replaced the fork and made preliminary adjustments with the ranges ,and really tuned in the power shift perfect , But Again real problem was linkage adjustment..(Still tinkering with that ) and a cruded up shifter shaft,, WD 40 bath helped the range shaft a lot .had a cracked head, so ,thad at ruscha shipped me good one ,, put in new fuel injectors ,put qt lucas engine seal in crankcase,,stopped front and rear seal leak ,,put Lucas Fuel stabilizer in tank and a cup or 2 of sea foam in a full tank ,,.gollly there was alot of grime in there ,,filters were nasty every time i changed them , ..the 1070 is the best starting big Diesel on the place , i use lucas products in everthing i own proudly,BECAUSE IT WORX ! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
