| Author |
Message |
David G Tractor Guru
Posted: Sun Dec 02, 2012 3:10 pm Post subject: H axle and cover back on. |
Both axles and the transmission cover are back on the H tonight.
It was not looking good earlier. The cover gasket shrunk, the brake seal was wrong and the axle seal was wrong. I put all the shafts back in and will put the correct seals in when I get them.
I tried welding a nut on the bolt that twisted off, but it just twisted off below the nut. I ended drilling it out and running a tap to clean it up. |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Sun Dec 02, 2012 3:47 pm Post subject: Re: H axle and cover back on. |
Good for you for getting it done.
Zach |
| Back to top |
Posted: Sun Dec 02, 2012 4:06 pm Post subject: Re: H axle and cover back on. |
My goal is to have it all buttoned up and full of lube before next weekend. The wrong seals did not help much.
I am going to paint the rims and center castings while the tires are off. The first coat is on both now. I will let the paint harden over the winter and change tires in the spring. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18247 Location: St. Cloud, MN
Posted: Sun Dec 02, 2012 5:01 pm Post subject: Re: H axle and cover back on. |
Good effort. Wrong parts are a show stopper. How did the brake band de-oiling go? Jim |
| Back to top |
Posted: Sun Dec 02, 2012 5:52 pm Post subject: Re: H axle and cover back on. |
Have not gotten to it yet, working on getting heavy parts on first. |
| Back to top |
jbp Long Time User
Posted: Mon Dec 03, 2012 6:28 pm Post subject: Re: H axle and cover back on. |
David, just how bad a job is removing the top cover and the upper transmission shaft? My H is popping out of 5th gear and the top cover seeps some oil so it needs some attention. About every seal in the tractor has been replaced except for the axle seals, just dread getting at it.
Those brake bands do flame a bit while burning off the oil but it didn't seem to hurt them as they will both slide the wheels without much effort, but still don't grab. Joe |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5376 Location: SE Wisconsin
Posted: Mon Dec 03, 2012 7:39 pm Post subject: Re: H axle and cover back on. |
| jbp wrote: | (quoted from post at 19:28:40 12/03/12) David, just how bad a job is removing the top cover and the upper transmission shaft? My H is popping out of 5th gear and the top cover seeps some oil so it needs some attention. About every seal in the tractor has been replaced except for the axle seals, just dread getting at it.
I did it a couple years ago to my H. It isn't too bad. It is a lot nicer than dealing with your problems!!! That would drive me crazy.
You can check out the project here. http://photobucket.com/FarmallH
A couple highlights.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
