| Author |
Message |
GP Hansen Regular
Posted: Sun Dec 02, 2012 6:30 pm Post subject: Froze up for 20 years |
I"ve decided to change the trans/diff sludge. It is a thick brown goo. My plan is to add several gallons of diesel and run it around the place a little bit and drop the drain plug and put in new oil. See any problems with this ? |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Sun Dec 02, 2012 6:49 pm Post subject: Re: Froze up for 20 years |
I think usually people drain the oil first and then put in kerosene or whatever to clean it out.
Zach |
| Back to top |
John G. Hasler Long Time User
Posted: Sun Dec 02, 2012 6:57 pm Post subject: Re: Froze up for 20 years |
I"d put a gallon or so of cheap oil in with the diesel just to be sure there is something there to provide at least some lubrication. |
| Back to top |
GP Hansen Regular
Posted: Sun Dec 02, 2012 7:20 pm Post subject: Re: Froze up for 20 years |
This sludge is so thick it hardly comes out it needs to be thinned. |
| Back to top |
John B. Tractor Expert
Posted: Sun Dec 02, 2012 7:24 pm Post subject: Re: Froze up for 20 years |
yes I would put some oil in it. It doesn't take long to scar a shaft with out oil! |
| Back to top |
the tractor vet Tractor Guru
Posted: Sun Dec 02, 2012 8:03 pm Post subject: Re: Froze up for 20 years |
Put a space heater on it to get the rearend hot and it will drain . Probably 140 weight and in this weather it is a weeeeee bit stiff. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18249 Location: St. Cloud, MN
Posted: Sun Dec 02, 2012 8:56 pm Post subject: Re: Froze up for 20 years |
For 10 minutes of no load cleaning, no oil is needed (the residual will do fine) if you feel unsure, jack it up and run it W/O even weight. Jim |
| Back to top |
davediehl@hotmail.com Tractor Expert
Joined: 04 Nov 2006 Posts: 1998 Location: Angola, IN (Northeast Corner)
Posted: Sun Dec 02, 2012 9:42 pm Post subject: Re: Froze up for 20 years |
If your fill cap is large enough, I have taken a boat bilge pump and placed it in a catch container (bucket). Stick the hose in the fill and let it run with diesel flowing. I gave mine 10 minutes and it was cleared out of all the junk. Then I filled it with a mix of diesel and oil to get the rest cleared. |
| Back to top |
gene bender Tractor Guru
Posted: Sun Dec 02, 2012 10:01 pm Post subject: Re: Froze up for 20 years |
Ive done that several times to get it flushed good. |
| Back to top |
FBH44 Long Time User
Posted: Mon Dec 03, 2012 1:47 am Post subject: Re: Froze up for 20 years |
I pulled the transmission cover plate off and drained everything then scraped the goo out with a 2" wood slat. I/m glad I did, the sludge was so congealed and heavy I don"t think it would have ever thinned out and drained. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
