Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
super c steering
blunted
PostPosted: Mon Dec 03, 2012 5:30 am    Post subject: super c steering Reply to specific post Reply with quote
put new bushings in, dosnt shimy no more, but did tighten steering up and realy can feel the over an inch of slop. says in the book no adjustment like in an A. true or false? thanks. gene, i will check the outer bearing thanks
gene bender
PostPosted: Mon Dec 03, 2012 6:52 am    Post subject: Re: super c steering Reply to specific post Reply with quote
There are no adjustments. You just replace worn parts and they work. That bearing on the end of the input shaft is realy important cause if it has play there will be end play and causing steering wheel "loose" play.
Janicholson
PostPosted: Mon Dec 03, 2012 8:30 am    Post subject: Re: super c steering Reply to specific post Reply with quote
If you have onl;y an inch of steering wheel rim travel as slop, you are as good as it is going to get. Be happy. Jim
blunted
PostPosted: Mon Dec 03, 2012 10:44 am    Post subject: Re: super c steering Reply to specific post Reply with quote
thanks, guys
Rick Remmert
PostPosted: Mon Dec 03, 2012 5:03 pm    Post subject: Re: super c steering Reply to specific post Reply with quote
Just got mine on my Super C finished this weekend. As Gene told me, replace the bearing on the end of the worm gear shaft. It turns a little play into a lot of sloppy steering. Also, turn the gear on top that the worm shaft runs against 180 deg. in rotation so the worm shaft has a new place to run on. Installed new seals, I did not install the bottom one "upside down" like the manual says. I put it in lip side out or down to seal the oil in. I have driven it and for 5 days now no oil leaks. Also make sure to trial fit the plug in the front that it is screwing all the way against the ball bearing. Mine was not.
blunted
PostPosted: Mon Dec 03, 2012 6:22 pm    Post subject: Re: super c steering Reply to specific post Reply with quote
looking at the big gear, looked ok. going to put bushing and bearing, new, and seal,. question? when puting worm gear in, with yoke at the end, is ther a center for the gear to sit? if one way to much make you not steer far enough way or the other? thanks. yes, gene, the bearing had hard , ruff spots in it.
blunted
PostPosted: Mon Dec 03, 2012 6:51 pm    Post subject: Re: super c steering Reply to specific post Reply with quote
how did you put your worm gear back in for the rite position for as the steering?
Ol' Gimpy
PostPosted: Tue Dec 04, 2012 8:34 pm    Post subject: Re: super c steering Reply to specific post Reply with quote
Did you check the U-joints in the steering shafts?? Seems almost all of the knuckles are worn/loose,held with nails,wire,or cotter pins,etc.Whatever was avaliable when something was lost.Most all of these tractors I see have the same looseness,for the same reasons.Like the guys mentioned,you can turn the steering worm gear 360 degrees and get new gear wearing teeth as a result.And also some looseness can be because of the worm shaft bearing and/or retaining nut being loose as well.
