| Author |
Message |
mdobbin New User
Posted: Mon Dec 03, 2012 6:25 am Post subject: ford 2000I Transmission |
I have a ford 2000I (4cyl. gas) with no 1st and reverse. Will a ford 950 transmission interchange? The 2000I is actually a 2030 model. |
| Back to top |
souNdguy Tractor Guru
Posted: Mon Dec 03, 2012 6:50 am Post subject: Re: ford 2000I Transmission |
a 4 cyl 2000 is essentially a reworked 601
you can swap in an 01 tranny of the same type with probably no mods or other parts swapping. ie.. 4spd in/out.
if it's a 5spd inthe 2000, use a dual clutch model, as that is what it should have.
on an older tranny, you may have spline and brake differences... and or may be needing the flywheel to match t he clutch..e tc. ( pinion tube ).. maybee some cut n paste there as well. |
| Back to top |
mdobbin New User
Posted: Mon Dec 03, 2012 8:25 am Post subject: Re: ford 2000I Transmission |
The 2000I have a 4 speed tranny and the 950 is a 5 speed. Thanks, Mike |
| Back to top |
Fordfarmer Tractor Guru
Joined: 12 Dec 2005 Posts: 6541 Location: Ladysmith, WI
Posted: Mon Dec 03, 2012 10:38 am Post subject: Re: ford 2000I Transmission |
It should work, but you will need the flywheel and the brake pedal shaft may be different. And maybe the splined connector - may have to fabricate one with coarse splines on one end and fine on the other. |
| Back to top |
Posted: Tue Dec 04, 2012 5:13 am Post subject: Re: ford 2000I Transmission |
didn't i just tell him that? :)
guess they like to hear it 2x..  |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
