Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
2n wiring trouble
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
mrice2311
PostPosted: Mon Dec 03, 2012 3:18 pm    Post subject: 2n wiring trouble Reply to specific post Reply with quote
I just converted my Ford 2N to 12 Volt using the Tisco 12V Conversion kit. I removed all old wiring and started new, following the diagram. Tractor started right up, runs good. Problem: My ammeter shows -30 when running, why? Also, I connected my lights to the bottom post of the resistor assy, but the lights don"t come on (they worked fine on my 6 volt system, and yes I changed all lights to 12 v bulbs). Any ideas or help would be appreciated. Thanks Mike
ChrisCos
PostPosted: Mon Dec 03, 2012 3:22 pm    Post subject: Re: 2n wiring trouble Reply to specific post Reply with quote
Just a guess, the original system was positive ground. The new 12v system is negative ground.
Run the wire through the back of the ammeter going in the opposite direction and it should show positive volts.
On a side note, the ammeters on both my 8N's are full of condensation and always show "0". The tractors don't seem to mind Smile
JMOR
PostPosted: Mon Dec 03, 2012 3:25 pm    Post subject: Re: 2n wiring trouble Reply to specific post Reply with quote
mrice2311 wrote:
(quoted from post at 19:18:06 12/03/12) I just converted my Ford 2N to 12 Volt using the Tisco 12V Conversion kit. I removed all old wiring and started new, following the diagram. Tractor started right up, runs good. Problem: My ammeter shows -30 when running, why? Also, I connected my lights to the bottom post of the resistor assy, but the lights don"t come on (they worked fine on my 6 volt system, and yes I changed all lights to 12 v bulbs). Any ideas or help would be appreciated. Thanks Mike
Unless you show us the specific diagram that you wired to, then even a guess on our part will be a WILD guess. Rolling Eyes
mrice2311
PostPosted: Mon Dec 03, 2012 3:29 pm    Post subject: Re: 2n wiring trouble Reply to specific post Reply with quote
Here is a copy of the wiring diagram that I used. Thanks. Here is the link to the diagram.
Untitled URL Link
tracman
PostPosted: Mon Dec 03, 2012 3:37 pm    Post subject: Re: 2n wiring trouble Reply to specific post Reply with quote
mrice2311 wrote:
(quoted from post at 16:18:06 12/03/12) I just converted my Ford 2N to 12 Volt using the Tisco 12V Conversion kit. I removed all old wiring and started new, following the diagram. Tractor started right up, runs good. Problem: My ammeter shows -30 when running, why? Also, I connected my lights to the bottom post of the resistor assy, but the lights don"t come on (they worked fine on my 6 volt system, and yes I changed all lights to 12 v bulbs). Any ideas or help would be appreciated. Thanks Mike
As has been said you can interchange the wires on the ammeter and it will read +30. However it should decay to 0 amps when the battery is charged up. I would make sure that the voltage on the battery falls between 13.8 volts and 14.5 volts when running. No more no less. A sustained 30 amps may indicate overcharging if your battery voltage exceeds 14.5 volts. The 30 amps could indicate a large electrical load as well.
JMOR
PostPosted: Mon Dec 03, 2012 5:38 pm    Post subject: Re: 2n wiring trouble Reply to specific post Reply with quote
mrice2311 wrote:
(quoted from post at 19:29:41 12/03/12) Here is a copy of the wiring diagram that I used. Thanks. Here is the link to the diagram.
Untitled URL Link
Unless they had changed, I thought that was how TISCO did their kits. It reads only alternator output (includes what is going into battery & what is consumed by loads), i.e., not simply net battery charging/discharging current. Therefore, since it is reading negative, that most likely means that ammeter terminals need reversing or if a loop style meter, run the wire through the loop in the opposite direction. The other possibility is that it reads negative all the time , engine running or not & in that case alternator is bad.
