| Author |
Message |
DennisinWI Guest
Posted: Mon Dec 03, 2012 5:27 pm Post subject: Perkins Diesel Serial Number |
I have a question on a Perkins Diesel serial number. It does not match a typical serial number. The serial number is:
LD038 MX
00153B
5X 0153
Thanks in advance. Any help is appreciated.
This is a 4-236 in a MF 175 S/N 202880 |
| Back to top |
chuck41 Long Time User
Posted: Mon Dec 03, 2012 6:26 pm Post subject: Re: Perkins Diesel Serial Number |
Hi, On a 175 sold in USA the eng. # should be
236 UA then 5 digit # starting w/7 or poss 8.
Chuck |
| Back to top |
DennisinWI Guest
Posted: Mon Dec 03, 2012 6:51 pm Post subject: Re: Perkins Diesel Serial Number |
Thanks for your reply. My parts manual and service manual show the engine # should be as you said in your reply. I do not believe the engine has been changed because the tractor appears to very original. Not sure whats going on here. Thanks |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Mon Dec 03, 2012 8:17 pm Post subject: Re: Perkins Diesel Serial Number |
I got in a big fight with a suppostabe diesel expert over this, he wanted 'just the engine serial number' I read this off my 165's engine boss, UA 212 etc etc, he said that wasn't a Perkins serial number. some expert huh? I suspect he had an old book infront of him with UK codes, but he was only an hour east of me.. the loser. |
| Back to top |
samn40 Tractor Expert
Posted: Tue Dec 04, 2012 12:42 am Post subject: Re: Perkins Diesel Serial Number |
Here is the serial number position on my very early British built 175 with the Perkins 236 engine it also starts with 236 UA Also I posted the same for my 188 it starts with 248UA. Most of these Perkins engines would have been built in Peterborough England.
Sam
| Back to top |
Posted: Tue Dec 04, 2012 12:45 am Post subject: Re: Perkins Diesel Serial Number |
I think you are looking at the casting numbers, which will be raised letters. The serial number will be stamped into the casting on a flat area just in front of the exhaust manifold. I have posted pics of the serial nos of my tractors.
Sam |
| Back to top |
Posted: Tue Dec 04, 2012 7:11 am Post subject: Re: Perkins Diesel Serial Number |
Finally found the pic of mine, see how close to the top of the block it is?
Nicer picture than Sam's. He wears out cameras fast.
I don't know what other people call these machined down high spots in a casting, but we call em 'bosses'.
| Back to top |
DennisinWI Guest
Posted: Tue Dec 04, 2012 9:53 am Post subject: Re: Perkins Diesel Serial Number |
Thanks for the replys. These numbers are stamped on a machined raised boss on the right side of the block just below where the head and block join at the #1 piston. My MF 180 shows its numbers in the same location as the 175 and as in the photos you provided. Do you think I have an oddball here?
I'm confused!! |
| Back to top |
FBH44 Regular
Posted: Wed Dec 05, 2012 3:50 am Post subject: Re: Perkins Diesel Serial Number |
I went through all this looking up the perkins.com web site for my MF 240-S. I know you don't care about the 240-S, but here's the info available.
Serial numbers on Massey 240-S rear differential housing;
Left rear transmission rib;
“5U102”
Right rear transmission rib;
“Type 9537 Serial F 05016 Model 240S”
Engine number ….. casting number on right side of engine block =
CE 97070
T 123235 C
CE = “engine family and type code”
= AD3.152 Perkins diesel engine
C = 3.152 Series of engines
CE = D3.152 (152 CID displacement)
97070 = “parts list number or SOS order reference number”
T = Turkey as country of origin
123235 = “engine serial number”
C = date of manufacture, 1997
Information from www.perkins.com |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
