Jubilee 3pt Doesn't Lift
Jay in WA
PostPosted: Thu Dec 06, 2012 10:08 pm    Post subject: Jubilee 3pt Doesn't Lift Reply to specific post Reply with quote
I recently repaired the trans in my Jubilee after it sat for about three years. The hyd. system was cleaned and filled with new fluid at the time of the trans fix. My 3pt doesn't lift every time I move the control lever. I looked inside while running the hyd's and can see a flow of oil coming into the hyd. reservoir. The lift piston doesn't move every time the control is moved. Is the piston bad or something else maybe? It still has the vane pump.
ASEguy
PostPosted: Fri Dec 07, 2012 3:15 am    Post subject: Re: Jubilee 3pt Doesn't Lift Reply to specific post Reply with quote
Jay, You should probably ask this question on either the Ford board or the 9N2N8N bord. You'll get a lot of help there. Gerard
Jay in WA
PostPosted: Fri Dec 07, 2012 8:45 am    Post subject: Re: Jubilee 3pt Doesn't Lift Reply to specific post Reply with quote
Thanks for your reply. This is all new to me. I wasn't sure where to post my question.
