SC Ignition Switch
Bud W
PostPosted: Tue Dec 04, 2012 8:14 am    Post subject: SC Ignition Switch Reply to specific post Reply with quote
With the push/pull Ignition Switch pulled out shouldn't I have voltage at the coil? Thanks
Wayne in MN
PostPosted: Tue Dec 04, 2012 8:47 am    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
ASSUMING THIS IS A BATTERY IGNITION: Do you have voltage to the switch? If so, then pulling out the knob should allow voltage to exit the switch. If there is voltage at both terminals then follow the wire to the coil.
IF THIS TRACTOR HAS BEEN CONVERTED TO 12 VOLTS: Check for a resistor that has failed between the switch & coil.
Janicholson
PostPosted: Tue Dec 04, 2012 8:48 am    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
If it is a point and coil ignition yes with a mag no.
IF NONE, the the use of a test light will help trace the issue. If it has a ballast resistor, it might be blown. Jim
Janicholson
PostPosted: Tue Dec 04, 2012 8:49 am    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
Just a few seconds!!! Jim
uncle henry
PostPosted: Tue Dec 04, 2012 9:20 am    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
wires backwards?
Bud W
PostPosted: Tue Dec 04, 2012 9:30 am    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
Found my problem- Thanks for the responses
Bud
steve alderman
PostPosted: Tue Dec 04, 2012 5:45 pm    Post subject: Re: SC Ignition Switch Reply to specific post Reply with quote
I done that few times wish they would have marked them 50 years ago
