| Author |
Message |
Gary C S New User
Posted: Tue Dec 04, 2012 9:02 am Post subject: moline za |
we have no fenders,fluid,or weights.we do have wheelie bars. tractor weighs 4000 lbs with about 200lb driver.we were wandering how much weight we would lose by removing belt pulley and pto? we would like to see if it can get to 3500 lbs with driver,without to much more trouble. has 12.4/38 rubber would like to go to 13.6/38 any thoughts if that will help much. seems like we have plenty of power. |
| Back to top |
m-m john Regular
Posted: Tue Dec 04, 2012 10:19 am Post subject: Re: moline za |
i have a z that i pull and 4000 is as light as i can get it. You will gain about 100 lbs or so going to 13.6 |
| Back to top |
Mopower Tractor Expert
Posted: Wed Dec 05, 2012 7:28 am Post subject: Re: moline za |
Removing the PTO and it's driving shaft id goot for about 30-40 pounds. I think the belt pulley drive is good for a few more, not to mention the pulley itself. If fenders are required, use the late R fenders. They look great, bolt on, and are much lighter. Run about half the required oil in the tranny. A "red nose" from a ZT is much lighter than the heavy cast tanks and radiator on the ZA. You may not want to change that for looks reasons. The ZT is really a bit lighter. I'm assuming all the hydraulics are already off the tractor. ZAS/ZTS/JTS axles, housings, and hubs are much narrower, therefore much lighter. I'd bet half the weight. My friend did this (minus axle housings) to his ZA and had it to 3600 or so. 3500 takes a bit more work and works much better with a ZT. The lightest I've seen is a 3000# ZT, but it's pretty tricked out. BTW, some brands and styles of tires (and wheels) are ligter than others. That's all I can think of right off the top of my head. |
| Back to top |
rpllr Regular
Posted: Wed Dec 05, 2012 2:33 pm Post subject: Re: moline za |
I had one down to about 3500-3600 without a driver and had about all off of it i could get. Made light weight brake pedals tube for a steering shaft no alternator air cleaner or fenders. |
| Back to top |
Baelee05 Regular
Posted: Thu Dec 06, 2012 6:09 pm Post subject: Re: moline za |
We had a 38 Z that we got down to about 3300 without a driver. Ran without pto, belt pulley and drive, starter, and fan. We used a plastic electric fan. Anyplace that has a cast plate was covered with aluminum. We cut the trans cover right up to the shifter and used aluminum. We cut off all cast mounting brackets like cultivator and fender mounts. We ground off a lot of cast iron in places. We ran without tubes in the tires. We were running steel wheels but cut as much steel out of the centers as we could get away with. Our next step was to spring for some aluminum rims. We were running 14.9x38's. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
