| Author |
Message |
BigMarv1085 Regular
Posted: Tue Dec 04, 2012 4:02 pm Post subject: Chain saw problem |
I traded some work for a poulan 385 pro bow saw last year. It had sat for years and I replaced the fuel lines and all new gaskets and diaphragm. Soaked it in carb cleaner for a couple days before new gaskets. It will run perfect for 5 or 10 minutes then bogs down and blows smoke. Adjusting doesn"t seem to help. A few days later it will start and run fine and the same thing starts. any suggestions? |
| Back to top |
DiyDave Tractor Guru
Posted: Tue Dec 04, 2012 4:34 pm Post subject: Re: Chain saw problem |
Have you checked to see if the spark arrester screen is carboned up, clogging the exhaust? |
| Back to top |
Idaho spud Regular
Posted: Tue Dec 04, 2012 4:38 pm Post subject: Re: Chain saw problem |
Big marv. Where are the high and low speed jets set at. By this I mean how far out are they set. Most all two cycles should be approx one turn out on the low speed jet and no less than approx 3/4 turn out on the high speed jet. If that's about where they are at the present get back with me we'll try another route. |
| Back to top |
JF in CT Regular
Posted: Tue Dec 04, 2012 4:48 pm Post subject: Re: Chain saw problem |
I'm betting you have something wrong with the exciter coil or secondary coil. Spark getting weak (smoking) before it quits altogether. Cools down and works fine until the cycle starts over.
Jim |
| Back to top |
Russ from MN Tractor Expert
Posted: Tue Dec 04, 2012 5:36 pm Post subject: Re: Chain saw problem |
Fuel tank not venting? |
| Back to top |
BigMarv1085 Regular
Posted: Tue Dec 04, 2012 5:46 pm Post subject: Re: Chain saw problem |
high adj 7/8 turn, low adj 1 turn but the vent valve was all messed up and I put one in from a weed eater that might be the problem, I have soaked that carb several times in carb cleaner, flushed with acetone and then blown out with air. |
| Back to top |
Idaho spud Regular
Posted: Tue Dec 04, 2012 6:30 pm Post subject: Re: Chain saw problem |
As one of the other guys mentioned, the fuel cap might not be venting right. After it quits ya if you open fuel cap and it blows gas back at ya it's not venting right. I have had saws that the ignition coil would put out too weak of spark after they got heated up. Normally the ignition is either good or bad but I have had them get weak after thay heat up. If it starts bogging down a quits ya, pull the plug and see if it has fire. If no fire, a bad ignition coil. |
| Back to top |
Michael Soldan Long Time User
Joined: 14 Aug 2007 Posts: 1347 Location: Exeter Ontario
Posted: Tue Dec 04, 2012 6:33 pm Post subject: Re: Chain saw problem |
In any other engine,what you describe sounds like a coil problem rather than a carb problem..coil gets hot and fails,coil cools down and saw runs again...get a new coil and see what happens |
| Back to top |
Goose Tractor Guru
Posted: Tue Dec 04, 2012 8:09 pm Post subject: Re: Chain saw problem |
I once had a small Poulan that would run fine for 10 or 15 minutes and quit. Had to let it sit for an hour or so and it would start again.
It was a bad coil. Cost about $20 online. Actually, it should have been still under warranty but three Poulan dealers wouldn't touch it 'cause they said they'd never get paid by Poulan. |
| Back to top |
guido Tractor Expert
Posted: Wed Dec 05, 2012 6:29 am Post subject: Re: Chain saw problem |
Hello Bigmarv 1085,
Check the mag to flywheel setting.
It may be close enough to scrape. It will start the engine, but get hot.
Make sure that is at least .010.
I set them at.012
Guido. |
| Back to top |
Chip812 Long Time User
Posted: Wed Dec 05, 2012 8:28 am Post subject: Re: Chain saw problem |
| Russ from MN wrote: | | (quoted from post at 20:36:00 12/04/12) Fuel tank not venting? |
+1 |
| Back to top |
BigMarv1085 Regular
Posted: Wed Dec 05, 2012 4:02 pm Post subject: Re: Chain saw problem |
I hchecked the vent and found that it was hard as a rock, ran it about 15 minutes and it ran fine with no vent in it. Looked online and can't find one anywhere, guess I will see if maybe one off a old weed eater will work. I really appreciate the help |
| Back to top |
