| Author |
Message |
Murray2 Regular
Posted: Tue Dec 04, 2012 6:46 pm Post subject: change front end Super C |
Hi, Plans are to change the front end on a Super C. What are the procedures to follow for safety in how to block up the front end while making the change? Thanks, Murray |
| Back to top |
Hattrick Regular
Posted: Tue Dec 04, 2012 6:53 pm Post subject: Re: change front end Super C |
When I did mine I just strongly cribbed under the bell housing and the motor just hung off the front while I took the front end off. |
| Back to top |
Dean Olson Long Time User
Posted: Tue Dec 04, 2012 7:01 pm Post subject: Re: change front end Super C |
Block rear wheels front and back on both sides. It can not be able to move any direction.
Place floor/ bottle jack on blocks so it will reach, if needed, and jack under flat spot on bell housing. Raise it just enough to get tires off
I remove both front tires and rims and lower jack till wheels are back on ground then unbolt. Once nuts are off raise jack just enough for studs to clear and roll it out. |
| Back to top |
tractorsam Long Time User
Joined: 19 Jul 2006 Posts: 1022 Location: Nova Scotia, Canada
Posted: Wed Dec 05, 2012 2:01 am Post subject: Re: change front end Super C |
Hi Murray, Are you taking the wide front off the one you've got at home? If so I find them to be finger biters. If you're pulling the cast support as well they tend to flop sideways (wooden wedges can help), also I find that as soon as I try to move one away from the tractor it will steer whichever way it feels like and be generally uncooperative. Maybe I can give you a hand if I'm around when you want to take it off? Sam |
| Back to top |
Brownie 450 Long Time User
Posted: Wed Dec 05, 2012 3:55 am Post subject: Re: change front end Super C |
We used to change between the narrow/ wide fronts every year for snow. Just locked the brakes & had a farm jack under the clutch housing. That was when we were in school yet. Would probably use a lot of cribbing now. |
| Back to top |
Murray2 Regular
Posted: Wed Dec 05, 2012 5:17 am Post subject: Re: change front end Super C |
Hi Sam. I will take you up on your offer to give me a hand to change the front end and yes the large cast iron piece would probable be quite unco-operative. Cheers, Murray |
| Back to top |
Murray2 Regular
Posted: Wed Dec 05, 2012 5:21 am Post subject: Re: change front end Super C |
Thanks for all your advice, I guess the safest thoughts is to block up securily under the clutch housing and let the engine hang there during the change. Thanks, Murray |
| Back to top |
LMack Long Time User
Posted: Wed Dec 05, 2012 3:21 pm Post subject: Re: change front end Super C |
It is not a big job if you have the cast centers for both. I did it both ways alone as a teenager back in the 60's. Use the bottle jack as suggested by others under the housing. Remove the four nuts holding the front pedestal then jack up the tractor front until the pedestal can be removed. Put the nuts and washers back on the pedestal for safe keeping. Remove the tires only after the pedestal is off the tractor even if you have to move the cast centers over. Install the tires on the wide axel before you install to the tractor. The wide front will not be exactly the same height as the pedestal so keep the jack in place. Have the four bolts handy to bolt the wide front to the front bolster. With the tires on it is much easier to align the axel. With the bolts in place attach the tie rods and you are done unless you need to adjust the tread width. Be sure to check for proper toe in alignment. Understand that the wide front for the SC was a nightmare to drive. Keep your front pedestal because you may put it back on once you have driven it for a while. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
