Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
966 slight miss?
DK44H
PostPosted: Tue Dec 04, 2012 6:47 pm    Post subject: 966 slight miss? Reply to specific post Reply with quote
I got the old 966 fired up today for the second time this year. Noticed that it sometimes had a slight miss. It didn't seem consistent just random and not bad either. It's been years since this thing has really had a load on it. Mostly PTO auger work and some raking. Will this clear up? Is it a symptom of sitting so long? Or is this a major deal? Otherwise it really runs good and always has. Has 5000 hours on it. Original.
Bob3 Martin
PostPosted: Tue Dec 04, 2012 6:59 pm    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
I don"t think you"ll be able to tell until you"ve run it for a while with a load on it.
All the diesels I have run better after they"ve done a little work.
DK44H
PostPosted: Tue Dec 04, 2012 7:12 pm    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
That's what I was thinking too. It could sure use a good workout. Got an old 5 shank ripper maybe I should hook it up and go tear up some ends and see if that helps
John A.
PostPosted: Tue Dec 04, 2012 8:04 pm    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
DK44H, AN IH D-414 is not an engine that does well on light loads! Idling around not really working. They are happiest at Wide Open under a heavy load Screaming at the Top of their Lungs really turning out work! So go do a days work with her (plowing, Chiseling) and see if she don;t straighten out Also they Tend to slobber oil out the exhaust too. When they have been run idling around on light duty. Get her to Full Operating Temp and hold it for a few hrs.!
IMO, I think it will Clear up after it had done some real work, not light duty kind of work. This is more of a system of Inactivity, No sustained temperature for long times, causing seals to seals to leak, carbon not to get burnt off the tips of the Injectors, Valves etc, etc, etc.
My 74, 966 is this way!
Hope this helps
Later,
John A
steve alderman
PostPosted: Tue Dec 04, 2012 8:52 pm    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
how old is the fule and the temp I just rebuilt my chalmers 190 xt and it sat for 5 years doing nothing and of course it had a full tank when it died and it doesnt care for it much
Brownie 450
PostPosted: Wed Dec 05, 2012 3:49 am    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
Has the valve clearance been checked lately? Could be 1 or 2 valves are needing adjusted.
DK44H
PostPosted: Wed Dec 05, 2012 5:33 am    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
The fuel is surely over a year old. I couldn't tell you the last time and valve adjustments had been made. As soon as it gets cold here and I get that cab tore off I will check all those things. It's hard to work in the shop much when it's 60 degrees in December!
Untitled URL Link
the tractor vet
PostPosted: Wed Dec 05, 2012 7:31 am    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
Well, with out standing next to it and hearing it for myself . (1) change the oil and do a new filter change (all OF THEM ) (2) dump some Lucas fuel conditioner in it and take it out and work her. Then see what ya have . Then i would then remove the hoods and do a valve adjustment BY THE BOOK and you do not have to pull the cab to do this.
DK44H
PostPosted: Wed Dec 05, 2012 7:25 pm    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
Thanks vet this is my winter project so I will definitely change all filters, oil, fuel, and air. Cab is coming off anyhow tho. Love them 66s with an open station. If we woulda just kept the 966 hydro, I wouldn't have to yank this one.
While I got your attention vet, is there any way to install a muffler under the hood and still come out the stock hole with a straight pipe to give it a little meaner look? Figured if anyone knew you would. Thanks
Jim Naden
PostPosted: Thu Dec 06, 2012 2:51 am    Post subject: Re: 966 slight miss? Reply to specific post Reply with quote
DK44H wrote:
(quoted from post at 20:25:42 12/05/12) Thanks vet this is my winter project so I will definitely change all filters, oil, fuel, and air. Cab is coming off anyhow tho. Love them 66s with an open station. If we woulda just kept the 966 hydro, I wouldn't have to yank this one.
If you chop off the front overhang of the fuel tank a 986 muffler would fit right in there. Wink
