| Author |
Message |
pd143 Guest
Posted: Thu Dec 06, 2012 7:34 am Post subject: 2-85 hydraulics |
The right side hydraulic lever, on my 2-85, when used will not extend and retract the cylinder as far as the left side does. No problems as far as function just rage of motion. I know there is an adjustment for speed but is there one for the range. |
| Back to top |
90 Percent Retired Regular
Posted: Thu Dec 06, 2012 1:51 pm Post subject: Re: 2-85 hydraulics |
Is this occuring on the same cylinder when switched from left to right? Could be the coupling locking up. The stroke is not controlled by the valve. We need more details. |
| Back to top |
pd143 Guest
Posted: Thu Dec 06, 2012 2:38 pm Post subject: Re: 2-85 hydraulics |
Using the same cylinder, the left side will extend and retract farther than the right. The cylinder when switched to my 1655 will operate the full range on both sides, so it is not the cylinder but something on the right side that is limiting its range of extension and retraction. I'm puzzled |
| Back to top |
Posted: Thu Dec 06, 2012 4:09 pm Post subject: Re: 2-85 hydraulics |
Does the valve return to neutral when the cylinder stops? Can you make the cylinder move to the end of it's stroke by holding the lever in the direction you want the cylinder to move? May be a bad check in the right side control valve, Just guessing at this time. I would tee a gauge into both lines going to the cylinder, if pressure equalizes before the cyl. reaches the end of it's travel the valve on that side will have to be dismantled to find the problem. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
