| Author |
Message |
Brady Miller Regular
Posted: Thu Dec 06, 2012 10:40 am Post subject: Farmall Super MTA Steering is Loose |
Does anyone know the likely parts needed, cost, and a place to purchase the parts to tighten up the loose steering on the tractor. Any pictures would be helpful. I am also looking for a power steering kit as well. How well does the priority valve system work versus the reservor and mounted pump system? |
| Back to top |
rustred Tractor Expert
Posted: Thu Dec 06, 2012 11:23 am Post subject: Re: Farmall Super MTA Steering is Loose |
pretty hard to tell whats needed without doing a visual inspection on it. wide front? narrow front? can be anything from steering wheel down to the front tires. |
| Back to top |
glennster Tractor Guru
Posted: Thu Dec 06, 2012 11:36 am Post subject: Re: Farmall Super MTA Steering is Loose |
carter and gruenewald equipment will have all the parts to rebuild the front bolster. for the power steering, external link sells all the stuff to run off a live pump. |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 956 Location: West central Wisconsin
Posted: Thu Dec 06, 2012 12:48 pm Post subject: Re: Farmall Super MTA Steering is Loose |
Brady as Rustred said it could be many things, but the first things I would be checking would be the U joint just under the hood and second would be the bearing on the end of the steering shaft on the top of the bolster. If them two things are good then it could be worm gear, steering gear, upper and lower bolster bushings, or the bolster shaft it self. HTH
Bob |
| Back to top |
Brownie 450 Long Time User
Posted: Thu Dec 06, 2012 12:51 pm Post subject: Re: Farmall Super MTA Steering is Loose |
First thing to check---pull the cover off the top of the bolster to see what is going on with the worm & sector gear. If the nut holding the sector gear down on the splined bolster shaft is loose, try tightening it. Remove key first. Worm & gear can be inspected also. |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6760 Location: Mitchell, SD
Posted: Fri Dec 07, 2012 6:17 am Post subject: Re: Farmall Super MTA Steering is Loose |
Get someone to sit on the seat and move the steering wheel while you check it out. Start at the two collars on the pedestal they must be flush and tight. Then work your way down the shaft, gears, bushing, rod ends and look for the looseness. Do you have an operators manual. Easy to get. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
