| Author |
Message |
SPT Regular
Posted: Thu Dec 06, 2012 11:36 am Post subject: Starting issue 88 |
I have an 88 that all of sudden will not start when cold, actually it will start and run for about ten seconds then die, can pull ten feet and it will fire right up, can shoot a little spirt of starting fluid, will start with starter, after once starting it, it will fire up immediately after that. Only have an issue when tractor has set for a few days. Again after you get it started, it will fire right up. Does have electronic ignition, but since it will start with a spirt of starting fluid, it seems to be a fuel problem. Any suggestions? |
| Back to top |
just a though Guest
Posted: Thu Dec 06, 2012 9:59 pm Post subject: Re: Starting issue 88 |
SPT:
It sounds like you have a restriction in your fuel line or you have crude floating in the bowl of your carb and once a load gets on its sucking the crud to your main jet a chocking it out.
Just a thought |
| Back to top |
SPT Regular
Posted: Fri Dec 07, 2012 6:31 am Post subject: Re: Starting issue 88 |
No, it really runs great after starting it, not a running issue at all, just won't start with starter unless you use starting fluid. |
| Back to top |
rrlund Tractor Guru
Posted: Fri Dec 07, 2012 7:12 am Post subject: Re: Starting issue 88 |
Sucking air through a bad gasket between the carb and manifold? Sucking air between the intake and head? Low compression? |
| Back to top |
chucksoliver77 Long Time User
Posted: Fri Dec 07, 2012 11:15 am Post subject: Re: Starting issue 88 |
SPT. check to see if your choke butterfly is fully closed. just a thought,chuck |
| Back to top |
ollie gm Regular
Posted: Fri Dec 07, 2012 3:10 pm Post subject: Re: Starting issue 88 |
I would guess that you have some water in your fuel. When the engine is cold the water beads in the carb roll into the openings of your idle and/or main fuel circuit and block the flow. This can take a few seconds to happen. After a pull or a puff of ether the water is forced thru the jets and it runs fine. Then the combination of vibration and ethanol based fuel the water drops are broken up to the point that they will pass thru the fuel circuits. |
| Back to top |
SPT Regular
Posted: Sun Dec 09, 2012 1:24 pm Post subject: Re: Starting issue 88 |
Thanks for all the suggestions, ended up being either a little dirt in the fuel or bad fuel, starts right up now. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
