MW Turbo on a 4010
hillbillyhook
PostPosted: Thu Dec 06, 2012 11:41 am    Post subject: MW Turbo on a 4010 Reply to specific post Reply with quote
I came across a M&W 5E111 turbocharger and exhaust manifold locally the seller thinks it came off a 4440 ... I am thinking more likely off a 4240... but either way he only has the turbo and the manifold, how much work and how many parts to make this work... I know M&W parts are hard to come by, just wondering what I would need in addition to the lube lines and parts to attach to the intake, do I have to use an external oil filter as well (I know it is recommended)... any pictures would be great...
Thanks in advance...
tim s
PostPosted: Thu Dec 06, 2012 12:08 pm    Post subject: Re: MW Turbo on a 4010 Reply to specific post Reply with quote
You would be ahead to toss the M&W stuff and use a 4430 manifold with a 4320 elbow and a little bit of fabricating to make it fit,,sorta like this one I put on a few months ago..
tomstractorsandtoys1
PostPosted: Thu Dec 06, 2012 5:42 pm    Post subject: Re: MW Turbo on a 4010 Reply to specific post Reply with quote
You should look for a 4020 radiator or at least the M&W seven blade fan and shroud.A 4010 tends to run warm with the fuel turned up let alone a turbo.But I will say the turbo 4010 ad 4020 tractors sure sound good.
larryanderson
PostPosted: Fri Dec 07, 2012 4:46 am    Post subject: Re: MW Turbo on a 4010 Reply to specific post Reply with quote
The way Tim does it is very clean and impressing especially where it is perfectly centered wish I was closer I would have him do mine.The M&W turbo setup was introduced nearly 50years ago along with several aftermarket products[duals ,pistons,goveners,hydraulics,wider fat fronts] that were ahead of their time an eventually became standard equiptment.Precision Diesel in RedOak Ia has what you need if you want M&W stuff.The turbo M&W used will make plenty of power but there are better ones that make more #s of boost and also whistle more if thats what you are looking for.I would add pan even 12Qt.JD will be better than 8 and fan&shroud help too.
hillbillyhook
PostPosted: Fri Dec 07, 2012 8:30 am    Post subject: Re: MW Turbo on a 4010 Reply to specific post Reply with quote
Thanks for the replies, I liked the 4430 setup when you posted them earlier... I thought this might be a cheaper alternative but I think I am going to hold out, the tractor has a 4020 radiator and 8 blade fan, it was updated when we "restored" it a few years ago and used it briefly for tractor pulling... now I was just hoping for a little more snot to run the 10ft brush hog in the thicker stuff... if it isn"t sold by Christmas I think I will take the ride to look at it...
Thanks again
