| Author |
Message |
PeteTheRookie Regular
Joined: 09 Dec 2010 Posts: 485 Location: Southern Maine
Posted: Thu Dec 06, 2012 1:34 pm Post subject: 1 Test of winter heaters on 4500 this AM |
Plugged in at 8ish. Started tractor at 10.
Overbite low was 25. About 28 at 8am.
30 by 10 am. Some wind.
Front and top of hydro reservoir warm.
Battery warm.
Rad hose above heater hot, intake on water pump warm.
But no flow thru to radiator.
Engine took 2 crank overs to start.
which is a improvement over the usual cold start.
Batteries could use a trickle charge.
The real test will be when its in the teens.
That is when I have a real hassle getting up enough RPM"s to start it.
Pete
| Back to top |
Wm. Neal New User
Posted: Thu Dec 06, 2012 2:36 pm Post subject: Re: 1 Test of winter heaters on 4500 this AM |
I have a battery blanket on both my 5000 and Super Dexta- both diesel), plugged in along with circulation heater for a couple of hours before starting makes a huge difference and they start with very few rev's even in -25to-30F weather. Blankets are not expensive. I have either for a quick shot (but very little) if needed.I am about 10hrs drive north of Minneapolis, where we really get winter! |
| Back to top |
JF in CT Regular
Posted: Thu Dec 06, 2012 2:43 pm Post subject: Re: 1 Test of winter heaters on 4500 this AM |
Are those 2 batteries in the box above the manifold? |
| Back to top |
Posted: Thu Dec 06, 2012 3:45 pm Post subject: Re: 1 Test of winter heaters on 4500 this AM |
Yes, 2 batteries. cheap ones too!
PO set it up that way and it works so why fix it.
Pete |
| Back to top |
Brian in MA Tractor Expert
Posted: Fri Dec 07, 2012 4:47 am Post subject: Re: 1 Test of winter heaters on 4500 this AM |
I have a lower hose heater on my 4000 and it normally takes about two hours plugged in when it's 10-15 degrees out to melt the snow on the hood, then she will fire on the first revolution. |
| Back to top |
RickB Tractor Guru
Posted: Fri Dec 07, 2012 9:27 am Post subject: Re: 1 Test of winter heaters on 4500 this AM |
You are supplying 630 CCA's through the parallel batteries while the OEM battery would supply 810 CCA's and a whole lot more reserve. If you have issues with cranking speed, consider dumping the dual cheapie setup. |
| Back to top |
Posted: Fri Dec 07, 2012 6:25 pm Post subject: Re: 1 Test of winter heaters on 4500 this AM |
Brian,
So what battery are you using. As RickB pointed out half my problem is most likely too low CCA.
If I leave the battery charger on it over nite.
It does start a whole lot better.
But as a rule I do not like to leave things plugged in unattended over nite
Wish it was like my "76 Toro 724 snow blower.
That has a plug in 110V starter on it.
Pete |
| Back to top |
Posted: Mon Dec 10, 2012 6:49 am Post subject: Re: 1 Test of winter heaters on 4500 this AM |
It is the biggest truck battery they had at the local Advance Auto that would fit. I don't remember the size, numbers, etc, but it isn't the 4DLT. Cranking hasn't been an issue for me. It will start without any cold weather aid down to about 35 degrees. Below that it needs a little help. |
| Back to top |
Posted: Thu Dec 13, 2012 2:26 pm Post subject: Re: 1 Test of winter heaters on 4500 this AM |
Ditto on the above freezing temp and starting.
Anything 32 and above it starts. Once it gets into the 20's takes a lot of cranking.
Billows cloud of white smoke.
Pete |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
