| Author |
Message |
luapp Regular
Posted: Thu Dec 06, 2012 7:01 pm Post subject: for Tx Jim again about 2355n |
i check priorty valve looked fine. trans is a little over full but when you stat it dip stick dont read at all. it just acts like the hyd pump isnt getten enouff oil. the line that goes to little tank up front feels like you can feel it vibraiting or surging now what. thanks for all the help. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13175 Location: Coyote Flats,Tx
Posted: Fri Dec 07, 2012 4:48 am Post subject: Re: for Tx Jim again about 2355n |
Did you ever check stand-by pressure? Pressure should be 2250 psi.Did you ever check hyd oil with engine running?? Hyd oil full mark is with engine running dipstick nut resting on top of threads. Have you tried the hyd functions with ind pto lever in the on & off positions?? |
| Back to top |
luapp Regular
Posted: Fri Dec 07, 2012 2:12 pm Post subject: Re: for Tx Jim again about 2355n |
put a gage in remote when i move valve gage bounces around 2000. the manual i have sayes to check trans oil with engin off. it has the dipstick in back by pto it has red plastic knob that sticks in tube. when you start tractor oil goes down fast and then dont read at all on dipstick. so i guss trans pump is worken. the pto and steering are all that work when warm. pto has no effect on anything. when you steer it it turns easy but if tou try and turn fast can feel a slight pulsing but still turns easy. it just seems like hyd pump is starven for oil thanks |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Dec 08, 2012 3:38 am Post subject: Re: for Tx Jim again about 2355n |
| luapp wrote: | | (quoted from post at 18:12:32 12/07/12) put a gage in remote when i move valve gage bounces around 2000. the manual i have sayes to check trans oil with engin off. |
I would nudge the standby pressure up to 2250 psi. I guess JD engineers changed their mind on the hyd oil level because on the older utilities operators manual stated to check hyd oil with engine running. |
| Back to top |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 253 Location: central Mass
Posted: Sat Dec 08, 2012 4:43 am Post subject: Re: for Tx Jim again about 2355n |
The manual for my 2350 says ck w/engine running. Same basic tractor. |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Dec 08, 2012 5:23 am Post subject: Re: for Tx Jim again about 2355n |
| 55deere70 wrote: | | (quoted from post at 08:43:36 12/08/12) The manual for my 2350 says ck w/engine running. Same basic tractor. |
Thanks for the update. I was fairly sure I was correct on "check with engine running" but with this "OLDTIMERS" I never know if I'm right or wrong. I think the 55 series utility hyd oil check will be with engine running.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
