Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
36 rows with 38 head
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters
Doug Wi
PostPosted: Thu Dec 06, 2012 7:21 pm    Post subject: 36 rows with 38 head Reply to specific post Reply with quote
Will a 4-38 gleaner head work ok with a 4-36 planter?
Fritz Maurer
PostPosted: Thu Dec 06, 2012 7:31 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Yes... if the corn is perfect every year, and you're not dragging the fan housing in the mud. Much better results if the planter is adjusted to fit the head.
sd pete
PostPosted: Thu Dec 06, 2012 7:49 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
SO SO. Neighbor did it one year. He adjusted the stripper plates off center he said that helped with header feed.
casecollectorsc
PostPosted: Thu Dec 06, 2012 8:21 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
The corn head is going to be moving the stalk to the outside on the outer rows. Any speed combining and the ears are going to fly over the outside snout and be lost. Don't think you can narrow the older gleaner heads. Ran one on a Case combine for quite a few years.
JMS/.MN
PostPosted: Thu Dec 06, 2012 10:00 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
????????????? Fan housing in the mud?
JMS/.MN
PostPosted: Thu Dec 06, 2012 10:02 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
It will work, but expect some loss....especially if the stalks are dry. Slower ground speed will help. Biggest loss will be on the outer rows.
IaGary
PostPosted: Fri Dec 07, 2012 4:57 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Can"t the header be slid into 36 inch rows.
The IH heads can be, maybe the Gleaners can as well.
Gary
DeltaRed
PostPosted: Fri Dec 07, 2012 6:44 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
If you just have a few acres you can get by.You can improove losses by just pulling 3 rows.Some heads you can 'adjust' the row width,others-no.Best thing is to plant 38"rows next year.
60 acre hillside
PostPosted: Fri Dec 07, 2012 6:46 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
When running in deep mud, or any mud for that matter, a combine does not always run in the direction the operator is aiming for. The result is running in an irregular pattern. The expression "with fan housing dragging" was referring to deep mud. The fan housing has no sirect effect on the corn head!
JMS/.MN
PostPosted: Fri Dec 07, 2012 6:52 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Yeah, it's fun steering with brakes!
cydectin
PostPosted: Fri Dec 07, 2012 6:55 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Either move the head in to 36" or move planter out to 38" if possible. Planter would be easier I would think.
MikeinKy
PostPosted: Fri Dec 07, 2012 10:13 am    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
It works fine. I do it every year. You can run 36" to 40" rows through a 38" head with no problem. Any one who says you can't hasn't shelled much corn. I plant 36" rows and run them through my 438 head on my L2 Gleaner as fast as you want to drive.
Doug Wi
PostPosted: Fri Dec 07, 2012 6:00 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Thanks for the input. Have a 438 head on gleaner F3. Have been planting 438 but just bought a 436 planter with no till coulters. Thinking of getting a bigger combine and gathering info as to what head I need.
gbs
PostPosted: Fri Dec 07, 2012 6:51 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
we picked 36" with a 38" head for several years works alright if your head is in good shape and adjusted correct ,your only off 3" on a 4 row head on the outer rows, inners are 1",we bought a good used A438 head this year, wanted a 36" but this one was to good to pass up it was in dire need of adjustment so we moved it to 36" while we had the tin off,row units weren't bad to move ,we shorten the dog bone drive shafts instead of buying new ones tin was the time consuming part,use to be several people that planted in 48" rows around here man i worked for picked a lot of it 3 rows with a 3 row 38" on a 410 Ferguson, most used a 2 row machine for 48"
casecollectorsc
PostPosted: Sat Dec 08, 2012 3:01 pm    Post subject: Re: 36 rows with 38 head Reply to specific post Reply with quote
Well, I would like to say you are a moron and have a lot of loss, but I won't.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
