Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TD-7G blade control levers
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
Larry from Mi.
PostPosted: Fri Dec 07, 2012 5:02 am    Post subject: TD-7G blade control levers Reply to specific post Reply with quote
I was wondering if the 2 lever blade control system could be changed to a one lever system. The valve unit should be the same to bolt to.
jm.
PostPosted: Fri Dec 07, 2012 5:31 am    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
You confuse me. You say two lever,, it should already operate UP & DOWN and ANGEL on one tall control then the tilt on the other short lever. No way to control all THREE spools on any ONE lever that I know of. Please explain your question more if I have missed it. Have several td 7/8/9 s clear on up to td 9H dressers but never have made any blade changes and doubt that it could be done. You could I guess but a electric switch on top of the tall lever and electric to the tilt. How long have you owned the unit.?
Larry from Mi.
PostPosted: Fri Dec 07, 2012 5:42 am    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
The one lever is for up and down and tilt. The other lever is for angle. The newer machines combine all three operations in one lever so I was wondering if they are interchangable.
Stick welding
PostPosted: Fri Dec 07, 2012 2:09 pm    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
I think it would it would be difficult to figure out a linkage to control all 3 functions with one lever.
jm.
PostPosted: Fri Dec 07, 2012 5:34 pm    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
Are you saying newer like DRESTA .. what model I have one less than 18 months old and it is still two functions on one with separate lever for other.
JOHNNYfromMI
PostPosted: Sat Dec 08, 2012 3:10 pm    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
Cat has put all three operations on one lever for years. You twist the lever to angle the blade.
Dennis K (WA)
PostPosted: Sat Dec 08, 2012 7:46 pm    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
Deere also
scotc
PostPosted: Tue Dec 11, 2012 8:17 pm    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
You could do it, but it would take some linkage fabrication, and I'm not sure how convenient it would be to twist the lever to control the angle by the time you built in enough leverage to run the valve.
How many hours you got on it? My dad's 8G has over 10,000.
Dr. Walt
PostPosted: Mon Dec 24, 2012 5:16 am    Post subject: Re: TD-7G blade control levers Reply to specific post Reply with quote
jm.
Quite simple really, it's called a Unitrol Valve. Stick forward = Blade down, Stick back = Blade up, Stick right = Angle right, Stick left = Angle left, Rotate the knob on top to the right (clockwise) = Tilt right, Rotate the knob on top to the left (counterclockwise) = Tilt left . Also, all three functions can be done simultaneously, but it works slower than if you did each function individually.
When I worked underground in the mines as a Union Certified, Senior Top Millwright / Mine Maintenance Mechanic , I worked on a lot of equipment that had a multi-function single joystick.
Doc
