Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
516 H
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Old Roy
PostPosted: Fri Dec 07, 2012 8:14 am    Post subject: 516 H Reply to specific post Reply with quote
Ok I just picked up a 516 H wheel horse. need mostly cosmetic work on it.
I know these were made to be simple to remove implements..I just don't see the releases.
Does anyone have a pic with directions for dummies ?
I need to take off deck and mount snow blade.
also I need to know, is there any difference of the size of the engine drive pulley that runs the tractor between a hydro, and gear drive ??
wisbaker
PostPosted: Fri Dec 07, 2012 8:53 am    Post subject: Re: 516 H Reply to specific post Reply with quote
I'm probably going to be putting the snow blower on my 525-H this week end I'll try to take some pictures. I'll warn you if the goal was to make implement changes easy they failed, they can be done with a minimum of tools, but it's not easy. more than once I've had the snow blower in the center mount with the entire weight of the tractor sitting on the snow blower and still can't get the darn thing to latch.
Maineman
PostPosted: Fri Dec 07, 2012 2:48 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Old Roy,
That's a nice tractor you've got there!
The tach-a-matic system is quite easy to use.
On the left hand side of the tractor you will see a small pin/ rod end sticking out of the front tach-a-matic.
It originally had a black rubber boot on it.
Pull that towards you. It should release the whole mechanism.
Move to under the motor, along the side of the frame, and find the same pin. Pull it out. That should release the mower.
The plow may attach under the rear axel. That tach-a-matic
Will have two thumb levers, pull them up to release them.
These things get rusty or dirty and may stick.
Sometimes their beat up and have burrs that need to be removed.
Joe
Maineman
PostPosted: Fri Dec 07, 2012 2:51 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
I believe the pulley on the trans is different.
But the one on the tractor is the same.
gab
PostPosted: Fri Dec 07, 2012 5:33 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
The tech-a-matic hitch system hasn't changed since 1973 I think. I used to collect dealer new model brochures. The 1986 book shows you how to install the mower in 65 seconds. To remove,
on the front.pulley box turn knob clockwise to loosen belt
pull pin out of pto pulley and swing half moon arm out, remove belt, push pin on left side pulley box, flip lever and it's on the ground.
start out with the mower in up position, push the button and flip lever on left frame brkt.
lower the deck and slide it out.
I won a 12 pack bet off a buddy of mine one time installing his deck in less than 65 seconds.
gab
PostPosted: Fri Dec 07, 2012 5:46 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Here's a 518 and a 520, was looking for a 516 but decided I got enough junk.
gab
PostPosted: Fri Dec 07, 2012 6:22 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Here's a blade pict.
Old Roy
PostPosted: Fri Dec 07, 2012 6:34 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Rained all day here and both my wheel horses are outside.. I have a one car garage dedicated to my Cub Den that has a broken cub, a broken little Craftsman , and a larger Craftsman ,( for now my main mower)
The wheel horse came with a parts tractor , although it is a little different looking, older model. (transmission will not let it be pushed backwards) but is does have those thumb levers you are talking about,(Can almost see the tip of it on the right side).... just possibly the transmission pulley will fit the 516 also. question from there is mounting the blade ? it has a bar on the back to click into those levers.
further up there is a vertical piece of metal with a hole in it. wondering how that is attached to the lift arm ? maybe a chain??? I had an older one long time ago ..seems to me it had a chain.
Old Roy
PostPosted: Fri Dec 07, 2012 6:41 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
I can't quite see the hook up mid way. I'm not even sure my blade has one that far forward.. I may have to move the upright part.
See another thing different .. you have a lever to change angle ?? mine must be missing ??
I can see how much of the frame stays on the tractor for the deck Thanks for the pic !
Maineman
PostPosted: Fri Dec 07, 2012 7:09 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Old Roy,
Wheelhorse plows attach at the rear axel.
They have a small upright bar in the middle that attaches to the lift arm with a chain or, if you want down pressure a bar.
Angle adjustment is accomplished through a right hand lever
(Usually missing some parts) wheel horse made short and long frame plows and later a front mount blade.
Can you post a picture of your blade?
Joe
Maineman
PostPosted: Fri Dec 07, 2012 7:14 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
This may help.
Maineman
PostPosted: Fri Dec 07, 2012 7:18 pm    Post subject: Re: 516 H Reply to specific post Reply with quote
Second try
joe csuti
PostPosted: Sat Dec 08, 2012 4:18 am    Post subject: Re: 516 H Reply to specific post Reply with quote
Goto link below,click on toro logo,enter 06-48BC01 in mod search on left side of pg,this is a complete assembly drawing/parts list for blade.
In pic you posted the orig handle is laying against blade,Thin rod from squeeze grip on handle went to a bellcrank mounted on angle bracket by handle mounting/pivot bolt,from bellcrank another thin rod ran to latch plunger to hold blade in position after changeing angle,also many of the pre C/early series C tractors used a chain rather than a bar to connect blade to lift handle arm(I have both styles),the chain/bar usually connected to center/intermost hole on rock shaft arm closet to lift handle
The usual method to install blade on tractor is remove pivot bolt for handle,remove or lay handle on ground,drive tractor over blade frame,slip cross shaft on A frame into quick attach on axle & lock,connect arm/chain to lift handle arm,reinstall arm for angle adj on blade.
toro
Old Roy
PostPosted: Sat Dec 08, 2012 10:52 am    Post subject: Re: 516 H Reply to specific post Reply with quote
Maineman wrote:
(quoted from post at 00:18:11 12/08/12) Second try
My blade is the exact thing as yours, but missing many parts
The tractor I believe it was on is this one
I am hoping these rear brackets woll work on the newer style tractor
Old Roy
PostPosted: Sat Dec 08, 2012 10:55 am    Post subject: Re: 516 H Reply to specific post Reply with quote
Thanks Joe, I see the missing parts here..
Dummy me, I have used this site many times for my Cub Cadet Never thought to look here ...
Goto page 1, 2  Next
Page 1 of 2
