Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1950 #30 steering box
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
illinoisduck
PostPosted: Fri Dec 07, 2012 11:13 am    Post subject: 1950 #30 steering box Reply to specific post Reply with quote
A friend has a # 30 that the front end woobles pretty bad on the road . He is in need of a fix. Any help will be appeciated. Thanks
Dave_Id
PostPosted: Fri Dec 07, 2012 4:13 pm    Post subject: Re: 1950 #30 steering box Reply to specific post Reply with quote
Buy an operators manual, and adjust the steering box to start with.
Masseynut(Australia)
PostPosted: Sat Dec 08, 2012 2:12 am    Post subject: Re: 1950 #30 steering box Reply to specific post Reply with quote
I would add that badly worn tie-rod ends and king-pin bushes will contribute to the "wobble". I would also check that the "toe-in" on the front wheels be adjusted afterwards to 1/4" to 3/8" of an inch.
Evan.
Mike in Mn.
PostPosted: Sat Dec 08, 2012 12:07 pm    Post subject: Re: 1950 #30 steering box Reply to specific post Reply with quote
If your talking a Massey Harris 30, first remove the grill and the tin cover over the steering box, if the shaft coming out of the box has a lot of play the bearings that hold that shaft can be adjusted. There is a lock nut towards the front of the box, loosen it and tighten the slug with the slot in it till you have the play out of the shaft. Have the front wheels jacked up so you can turn them. then tap the adjustment, the one above the jam nut with the capscrew through the slot to tighten or loosen the sector adjustment. Of course loosten the capscrew first, you should be able to get all the slack out of the steering gear, be sure to turn the wheel lock to lock cause of wear it might get sticky after you get off center. From the factory those sectors had 140 wt. gear oil in them, which is lone gone. Install a grease fitting in the plug hole and pump the sector full of grease, good luck.
