SOS Operation question
Goto page 1, 2  Next
white halftrack
PostPosted: Fri Dec 07, 2012 11:19 am    Post subject: SOS Operation question Reply to specific post Reply with quote
Hello again everyone. I am working on my late 1961 SOS 971 152xxx tractor. The tractor shifts through all gears well with no problems at all, but in Park, if placed on an incline it rolls down. Is it supposed to do this or should it lock in place? It is a 312259 transmission casting and the fluid level is good filter clean. I adjusted the bands according to the manual and it still shifts everywhere fine, but no park hold. Any suggestions? Otherwise kinda liking this machine.
Thanks.
Jason
souNdguy
PostPosted: Fri Dec 07, 2012 11:34 am    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
here's a link to john smith's sos troubleshooting.
i'd check that first one.. as it sounds like it is going to neutral in park, assuming it is adjusted correctly and actually making it to park.
John Smiths site sos troubleshooting
Dean
PostPosted: Fri Dec 07, 2012 11:56 am    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
The transmission should lock the driveline when in Park though there will likely be a delay prior to engagement.
Dean
Larry NCKS
PostPosted: Fri Dec 07, 2012 3:34 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
B2 & B3 make Park on that machine. These are spring applied. It seems odd that all ratios work and it still rolls away in Park. Are you sure you have the proper manual? Something surely sounds off on band adjustment to me.
awhtx
PostPosted: Fri Dec 07, 2012 3:37 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
Many SOS operators have reported that the tractor will roll a bit after P is selected. The most common cure is to place the selector in 5 (IIRC) and then quickly move it to P. Fortunately I've never had this problem with either of my SOS tractors (971 & 5000).
showcrop
PostPosted: Fri Dec 07, 2012 3:48 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
I use my 971 quit a lot in the summer. Before the SOS warms up, it will creep for a second or two in park, but once it gets warmed up it is pretty much instantly in.
kly
PostPosted: Sat Dec 08, 2012 9:56 am    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
lock the brakes and it won't go anywhere.
Larry NCKS
PostPosted: Sat Dec 08, 2012 11:48 am    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
Kly wrote:
(quoted from post at 12:56:55 12/08/12) lock the brakes and it won't go anywhere.
I don't think that addresses his concern. I believe he wants a fix, not a bandaid.
pete black
PostPosted: Sat Dec 08, 2012 12:41 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
are sos transmission tractors equipped with lockable
brakes? been a few years since i owned one but i
believe my 64 4 cylinder diesel was not equipped
with lockable brakes.
pete black
souNdguy
PostPosted: Sat Dec 08, 2012 12:54 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
no pawls?
pete black
PostPosted: Sat Dec 08, 2012 1:30 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
now i remember, thanks.
Larry NCKS
PostPosted: Sat Dec 08, 2012 3:18 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
pete black wrote:
(quoted from post at 15:41:45 12/08/12) are sos transmission tractors equipped with lockable
the early 01s were, if not all the 01s. the 4 cylinder 000s were not. I can't speak to the '65 - '74 models
Scott PA
PostPosted: Sat Dec 08, 2012 6:35 pm    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
Try shifting quickly from 5th to park to see if it holds.
Dean
PostPosted: Sun Dec 09, 2012 10:52 am    Post subject: Re: SOS Operation question Reply to specific post Reply with quote
Tough to do on the SOS tractors without brake locks.
For this very reason, I installed brake locks on my 64 4000 SOS.
Dean
Goto page 1, 2  Next
Page 1 of 2
