| Author |
Message |
KG Puller Guest
Posted: Fri Dec 07, 2012 11:42 am Post subject: Wd 45 Stroke |
Is it possible to stroke a wd 45 to 5inches and use my stock rods. If so what pistons could I use. Thanks |
| Back to top |
ss409 Regular
Posted: Fri Dec 07, 2012 12:50 pm Post subject: Re: Wd 45 Stroke |
seen em at 5.5 with stock rods with light clearence work on the cam. |
| Back to top |
bp4455 Regular
Posted: Sat Dec 08, 2012 10:44 am Post subject: Re: Wd 45 Stroke |
if you do 5.5 you will have to cut out sections of the oil pan and weld cups on it. that being said, i dont think 5" is enough to bother with a welded crank. you can get 4.875 with an offset grind and buda rods. |
| Back to top |
Allis puller New User
Posted: Tue Dec 11, 2012 4:31 pm Post subject: Re: Wd 45 Stroke |
Yes you can. also i have an allis puller with a 7" stroke and the only clearance work i done was in the block which wasnt much. |
| Back to top |
MLPANKEY Tractor Expert
Posted: Wed Dec 12, 2012 4:18 am Post subject: Re: Wd 45 Stroke |
| Allis puller wrote: | | (quoted from post at 17:31:39 12/11/12) Yes you can. also i have an allis puller with a 7" stroke and the only clearance work i done was in the block which wasnt much. | dont take this as me saying you dont have seven inches of stroke cause you may have but if you have left the mains in the original place then you have had to do some major clearancing . here is a picture of the oil pan rail on a 6 inch stroke .
[IMG]http://i738.photobucketphotobucket.com/user/pankeyc/media[IMG]http://i738.photobucketjavascript:void(0);
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
