1655 transmission lube pump chain
445mm
PostPosted: Thu Dec 06, 2012 12:12 pm    Post subject: 1655 transmission lube pump chain Reply to specific post Reply with quote
What size chain and length goes on the two sprockets that run the trans lube pump?
ejr-IA.
PostPosted: Fri Dec 07, 2012 11:13 am    Post subject: Re: 1655 transmission lube pump chain Reply to specific post Reply with quote
I think that the 1655 did not use that transmission lube system with the chain untill you got into the 1755 and up.Didn't they use a gyro gear pump driven off a transmission shaft external on trans houseing.Maybe I'm wrong.
J. Schwiebert
Guest
PostPosted: Fri Dec 07, 2012 2:47 pm    Post subject: Re: 1655 transmission lube pump chain Reply to specific post Reply with quote
No you are not wrong, but very late ones do use a chain drive.
carolina oliver
PostPosted: Sat Dec 08, 2012 5:05 pm    Post subject: Re: 1655 transmission lube pump chain Reply to specific post Reply with quote
I own a 1655 Our dad bought new. I have original manual and it has WHITE 1655 on front cover pics.. so may be late model..
It definitely has the chain drive inside. I also have a parted out 2-70 that has the chain inside it..
