| Author |
Message |
J W Ferguson New User
Posted: Fri Dec 07, 2012 1:45 pm Post subject: 520 cooling system |
I am rebuilding an old 520 and I have had a cooling problem in the past. I have noticed the radiator core sits 1-1/2 inches away from the fan at the nearest point. I have replaced the core in the past and it will only fit one way in the housing. I am suspecting the plates on the top and bottom of the core may be located wrong from the manufacturer. If the top and bottom plates had been flipped over at assembly, I could gain and inch, closer to the fan. If anyone knows what the normal clearance is from the fan to the core, I would appreciate hearing. |
| Back to top |
Bob Harvey Tractor Guru
Posted: Fri Dec 07, 2012 2:22 pm Post subject: Re: 520 cooling system |
Second guessing JD on a tractor that age is probably fruitless, even silly. They had some pretty smart/experienced engineers while designing these machines. I suspect that the space from rad core to fan has something to do with air flow, changing it may be a serious mistake. HTH |
| Back to top |
Machinery-Man Tractor Expert
Posted: Fri Dec 07, 2012 3:04 pm Post subject: Re: 520 cooling system |
why don't you locate another machine in area and check the specs before changing anything around. |
| Back to top |
deeretails New User
Posted: Fri Dec 07, 2012 4:34 pm Post subject: Re: 520 cooling system |
If the fan shroud is in place I don't think the fan to radiator distance is critical. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
