Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Hey F-I-T or buickanddeere
Post new topic    Yesterday's Tractors Forum Index -> John Deere
MBdeere
PostPosted: Fri Dec 07, 2012 3:39 pm    Post subject: Hey F-I-T or buickanddeere Reply to specific post Reply with quote
Im working on that right hand main seal on that 730. I got that pulley off so far. Question is to remove the right main bearing housing do I need to take off any oil lines in the inside. The service manuel does not say that I need to. I have to find a gear puller big enough to pull off that PTO gear. I may not get time to work on it again till next week. Also I used the pony engine to motor over the diesel with out compression to make oil pressure on the diesel. It looks to me that the main seal is not leaking it looks to be leaking right at the bottom of the main bearing housing maybe its the gasket for the main bearing housing to the main case. What do you think?
F-I-T
PostPosted: Fri Dec 07, 2012 7:35 pm    Post subject: Re: Hey F-I-T or buickanddeere Reply to specific post Reply with quote
The RH main is oiled by the crankshaft drilled oil holes. Once you have the PTO gear off, the oil seal can be clawed out without removing the main bearing housing. If you think it is leaking around the main, the housing can slide out, but you may have to support the crank to keep things in line as you slide it off to replace the gasket. Could be it is just loose...
Machinery-Man
PostPosted: Fri Dec 07, 2012 7:42 pm    Post subject: Re: Hey F-I-T or buickanddeere Reply to specific post Reply with quote
I always use a little heat on the gear...not too much will make it easier pulling off and getting back on....
