Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4690 hyd. valves
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
DC3puller
PostPosted: Fri Dec 07, 2012 5:50 pm    Post subject: 4690 hyd. valves Reply to specific post Reply with quote
My 4690 hyd. valvs arn't puting out enough preasure pump preasure fine are thy wore out can they be rebuilt wouldn't think all four would be bad. If bad where can a guy get some good ones at?
mEl
PostPosted: Sat Dec 08, 2012 12:42 pm    Post subject: Re: 4690 hyd. valves Reply to specific post Reply with quote
Where did you measure the pump pressure?
mEl
JT's RandR
PostPosted: Sun Dec 09, 2012 11:19 am    Post subject: Re: 4690 hyd. valves Reply to specific post Reply with quote
The pressure's were taken on each outlet they all were around 2000 psi but as soon as you moved the lever to the neutral position the all leak off horible. We also did a flow check with a flow meter and all of the remotes were below there rated gpm. So one mentioned a small screen filter that is before the blocks could this cause these problems?
mEl
PostPosted: Sun Dec 09, 2012 12:21 pm    Post subject: Re: 4690 hyd. valves Reply to specific post Reply with quote
DC3 puller, on the tractor pulling forum I posted a pic of a DC4 puller we built, It is under D tractor for pulling, thought you might like to see it, also a link to a video of it pulling at a local pull here in Pa.
The pressure is adjustable on the compensator valve for high pressure, Are you sure the flow adjustments were wide open?
How far down were the flow readings from specs?
Do cylinders leak down badly with weight on them?
mEl
JT's RandR
PostPosted: Mon Dec 10, 2012 4:51 am    Post subject: Re: 4690 hyd. valves Reply to specific post Reply with quote
The services manual says no less than 20 gpms coming out of the remote valves. the valves had readings of 16,10,3,6. The one with only 10 has no lifting presure you put a load on it and it does nothing. There is only one valve with flow control and it is the bad one and we have tried it all the way open and closed off.
