| Author |
Message |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 9:55 am Post subject: Removing steering tube tool box on C Pic |
How does the tool box come off the steering tube ? It has a square brace on the bottom & wont come thru the oblong hole in the box .
| Back to top |
Dick L Tractor Guru
Posted: Sat Dec 08, 2012 10:00 am Post subject: Re: Removing steering tube tool box on C Pic |
That could be a problem. (:^D
You remove the steering wheel and take it out the other way. More bolts to remove to make it quicker with less welding to get it back to original. (:^D |
| Back to top |
Roger H MI Regular
Joined: 29 Sep 2007 Posts: 216 Location: Central Michigan
Posted: Sat Dec 08, 2012 10:06 am Post subject: Re: Removing steering tube tool box on C Pic |
I just obtained an Allis B and I think everything came through behind the steering wheel. But there were brackets that had to be removed on the tool box. I will have to go down to my shop and check. I'm not an Allis B expert, But I have just tore one down and getting ready to reasemble. Cute little tractor though. |
| Back to top |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 10:07 am Post subject: Re: Removing steering tube tool box on C Pic |
The wheel is off but cant slide the box up the tube. |
| Back to top |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 10:11 am Post subject: Re: Removing steering tube tool box on C Pic |
I guess I need to remove the electrical stand. |
| Back to top |
acken fromwisc Regular
Posted: Sat Dec 08, 2012 5:25 pm Post subject: Re: Removing steering tube tool box on C Pic |
did you remove the gas tank too? The tube should slid up the steering shaft after the steering wheel is taken off. The tube clamp has to be removed. |
| Back to top |
chalmersbob(Pa) Regular
Posted: Sat Dec 08, 2012 7:32 pm Post subject: Re: Removing steering tube tool box on C Pic |
Remove the steering wheel, remove the clamp over the steering tube in front of the steering wheel. Remove the gas tank, then the tool box by sliding it up the tube and between the tube and the post. You may have to loosen the steering gear box to get some play at the post.
The square part is welded to the round tube. Depending what you want to do, you may not have to remove everything. I just worked on my steering gear box and only had to remove the gas tank and the tool box. LOL Bob |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 09, 2012 6:47 am Post subject: Re: Removing steering tube tool box on C Pic |
Yea I just pulled the tube & tool box off together & pulled the steering box off the tractor. Thought it might be better for me since i've never done this before. |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 09, 2012 6:50 am Post subject: Re: Removing steering tube tool box on C Pic |
Tank is off- I just slid the tool box & tube off together. The tube wouldn't come thru the oblong hole in the tool box . |
| Back to top |
Dick L Tractor Guru
Posted: Sun Dec 09, 2012 11:20 am Post subject: Re: Removing steering tube tool box on C Pic |
Shoulda took more pictures. This was a quick tear down.
click
| Back to top |
Dick L Tractor Guru
Posted: Sun Dec 09, 2012 11:25 am Post subject: Re: Removing steering tube tool box on C Pic |
Main reason I took these pictures was to show how to remove parts and have the tractor stable with jack stands under the drawbar and where to put a jack under the torque tube to have a solid three point position. |
| Back to top |
