| Author |
Message |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 12:23 pm Post subject: worn pawl - Pic |
Just got the steering arm out of the box - looks flat on both sides one side more than the other.Would this cause excessive slack in the wheel ? Bad enough to replace ???
| Back to top |
Dick L Tractor Guru
Posted: Sat Dec 08, 2012 1:08 pm Post subject: Re: worn pawl - Pic |
It sure is bad enough to replace. Did you fine a pawl? I have not dug thru my home tool box where I might have one. I thought I saw one a year or so ago somewhere. I made a new one for someone last spring I think. I have some stock to make some in my tool shop but as I said I will not be able to get open to make one before the end of this month. If I find one in my tool box you can have it. |
| Back to top |
Mark-Ia Long Time User
Posted: Sat Dec 08, 2012 2:35 pm Post subject: Re: worn pawl - Pic |
Look on Ebay for Steering pin.
Sort by:Time: ending soonestTime: newly listedPrice + Shipping: lowest firstPrice + Shipping: highest firstPrice: highest firstDistance: nearest firstBest Match
STEERING PIN John Deere M 40 MT MC MI 40T U S C T V
Returns: Accepted within 14 days |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50439 Location: Lake of the Ozarks area of MO
Posted: Sat Dec 08, 2012 6:00 pm Post subject: Re: worn pawl - Pic |
I have 2 part Cs on hand and both still have the steering boxes on them if you find you need parts. E-Mail is open as always |
| Back to top |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 6:32 pm Post subject: Re: worn pawl - Pic |
Thanks Dick,I need one but I need to get this "C back together ASAP before I forget how to put it together !lol If you find one let me know & I'll take it.Do you have the dimensions - I might could get one made at a local machine shop.
Thanks Bobby |
| Back to top |
Bobby 9891 Regular
Posted: Sat Dec 08, 2012 6:37 pm Post subject: Re: worn pawl - Pic |
Ok thanks - if I can get the dimensions I might can get one made at a local machine shop. |
| Back to top |
bg/mo Regular
Posted: Sat Dec 08, 2012 6:39 pm Post subject: Re: worn pawl - Pic |
yup it is worn enough, weld it up and smooth it out, any other used one is gona be about the same |
| Back to top |
chalmersbob(Pa) Regular
Posted: Sat Dec 08, 2012 7:38 pm Post subject: Re: worn pawl - Pic |
Just go to your local John Deere dealer and ask for AM1515T Follower, used on the JD M.
LOL Bob |
| Back to top |
mdtractormechanic Regular
| Back to top |
Ted in NE-OH Regular
Joined: 28 Nov 2012 Posts: 266 Location: Austinburg Ohio
Posted: Sat Dec 08, 2012 8:17 pm Post subject: Re: worn pawl - Pic |
Tracy Martin on the other Allis Chalmers site sells them for $25 each. |
| Back to top |
Bobby 9891 Regular
Posted: Sun Dec 09, 2012 6:42 am Post subject: Re: worn pawl - Pic |
The local JD dealer doesn't have one but found one in Dallas,Tx. $78.00 !! Sounds way high to me - seeing these other price options. |
| Back to top |
Dick L Tractor Guru
Posted: Sun Dec 09, 2012 7:19 am Post subject: Re: worn pawl - Pic |
Because you are having problems that seem to be overloading I will look this morning for one and if I find it the cost will be astronomical as is anything I help lost souls. (:^d
Total charge _______________ notta
You must email me your address. |
| Back to top |
