Oil bath air breathers
Larry O
PostPosted: Sat Dec 08, 2012 4:24 pm    Post subject: Oil bath air breathers Reply to specific post Reply with quote
Did I read on here a while back that someone sells the wire mesh for inside the 2N breather?
Second question is there a gasket/seal between the top and the body of the breather
Thanks Larry O
Bruce (VA)
PostPosted: Sat Dec 08, 2012 5:05 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
I'm pretty sure this site sells the wire mesh; I know Just8N's does.
There is a cork gasket between the cup & breather canister.
75 Tips
Larry O
PostPosted: Sat Dec 08, 2012 5:10 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
Thanks Bruce for the quick reply
that answers the part about the bottom one what about the top part on a through the hood 2N I guess it is the same ?
Bruce (VA)
PostPosted: Sat Dec 08, 2012 5:21 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
Can't help you w/ the through the hood part.....8N's didn't have that option.
Harold or Chris or one of the other guys w/ 2 or 9N's will be along shortly w/ that answer.
Larry O
Ultradog MN
PostPosted: Sat Dec 08, 2012 5:35 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
When I read the topic I thought you were another of those who thought they would improve on Henry and add a paper filter or some such.
Looks like Bruce has you covered.
Good luck.
55deere70
PostPosted: Sat Dec 08, 2012 5:44 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
Until now I never knew there was supposed to be a cork gasket between the cup and canister. I guess you learn something everyday! Seems to fit pretty tight without one.
Larry O
PostPosted: Sat Dec 08, 2012 6:09 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
No I'm with you I like the oil it is just that mine needs a little TLC The insides are trash and the top rattles
Royse
PostPosted: Sat Dec 08, 2012 6:19 pm    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
Larry O wrote:
(quoted from post at 21:10:27 12/08/12) Thanks Bruce for the quick reply
Larry, I wish I had a definitive answer for you, but I don't.
Here's what I do have:
The through the hood air breather was a dealer installed option.
I have two of them, and my two are not the same.
One doesn't come apart at all on the top of the air breather, so no
place to put a gasket on that one.
The other one is held on with a metal band type hose clamp and
tapered metal to metal contact. No ridge to hold a gasket.
Maybe some did, some obviously did not.
Does yours have a place for a gasket or fit loose enough to put one in?
Larry O
PostPosted: Sun Dec 09, 2012 5:42 am    Post subject: Re: Oil bath air breathers Reply to specific post Reply with quote
Royse
Mine is held on with a metal hat band and thumb screw like some of the lower cans there doesn’t seem to be a place for a gasket or seal but it is loose enough to very, very slowly rotate above half throttle maybe I have the wrong clamp
Larry
