Josh Blackburn
Goto page 1, 2  Next
algar
PostPosted: Sat Dec 08, 2012 4:33 pm    Post subject: Josh Blackburn Reply to specific post Reply with quote
What is the largest stroke crank for a 48 A that is semi reliable? What is the cost?
Josh Blackburn
PostPosted: Sat Dec 08, 2012 5:07 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
9 inch with 3 inch pin would be very reliable. Longevity of 8-10 years typically. 1400 includes crank flywheel and driver balancing
algar
PostPosted: Sat Dec 08, 2012 5:14 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
what is the largest bore I can go with a stock block
Josh Blackburn
PostPosted: Sat Dec 08, 2012 5:16 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Depends what year and which block used
algar
PostPosted: Sat Dec 08, 2012 5:33 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
48
Josh Blackburn
PostPosted: Sat Dec 08, 2012 5:43 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
5.75 will be max reliably. 468 cube. Mid 80's for hp
Bradracer18
PostPosted: Sun Dec 09, 2012 4:07 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Josh-
I still have not found time to call you, been very busy at work and on the farm before weather hits. I'm still interested. Do you also do the work besides the crank (ie: head, pistons, rods, etc etc)??
Josh Blackburn
PostPosted: Sun Dec 09, 2012 6:36 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
I do 90% of the work myself. When it comes to billet rods and
pistons I will contact some others I know who make a nice
product. I build my own Cranks, welded rods, carbs, heads,
cams, and etc
JD A Puller 51
PostPosted: Sun Dec 09, 2012 8:28 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Josh - What would the HP be with a PB bored to 6.125. Thanks
showcrop
PostPosted: Sun Dec 09, 2012 8:52 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Josh Blackburn wrote:
(quoted from post at 18:43:46 12/08/12) 5.75 will be max reliably. 468 cube. Mid 80's for hp
School me a little here, just curious about why build a 468 cube A when As frequently pull against Gs which can run 825 cubes?
Buster R
PostPosted: Sun Dec 09, 2012 9:53 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Just Recieved B parts form Josh great job on everything!! Crank amazing job rods same all around GREAT Job!! Highly recommend for all u guys building a 2 cylinder!! And mostly quailty and spot on when he gives u a time frame. Already sent all my G parts to him day after got B parts back! Thanks Josh keep up the Good Work
Josh Blackburn
PostPosted: Sun Dec 09, 2012 10:42 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Around here it takes a 470 cube a to run in antique classes.
Good tracks and good competition.
Josh Blackburn
PostPosted: Sun Dec 09, 2012 10:43 am    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Last A I did that size with cyclone head made 99 hp on Dyno at 600 pto speed. Runs really strong.
Bradracer18
PostPosted: Sun Dec 09, 2012 1:05 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Sounds good Josh, exactly what I'd like to hear and your review above sounds great to me. I like to hear good results and on time delivery! I really don't know what it will take as far as cubic inches to be competitive, nor do I have any idea as to the amount of money its going to take. I'm not sure if you are reworking my head, or need a whole new one. Same with carb. I guess I've got a lot of variables that I'm not sure on that sometime I'll need clarified as best as possible.
Josh Blackburn
PostPosted: Sun Dec 09, 2012 1:51 pm    Post subject: Re: Josh Blackburn Reply to specific post Reply with quote
Brad give me a call. Always best to talk rather than type.
9892775366
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
